Lowered Vette
Old Mar 7, 2014 | 11:42 AM
Trae1976's Avatar
Trae1976
Originally Posted by AirborneSilva
That looks great! I've already lowered my front by cutting 1 coil and want to lower back a bit but was wondering why I need to buy the 8" bolts for the back when I can just go buy a couple 8" grade 8's, is there a difference?
Shoulder length may be the biggest difference.
Too much shoulder = not much height adjustment.
No shoulder = threads where you don't want them.
Old Mar 7, 2014 | 11:47 AM
AirborneSilva's Avatar
AirborneSilva
Thanks Trae
Old Mar 7, 2014 | 12:46 PM
tektrans's Avatar
tektrans
Nice job-looks great!
Old Mar 7, 2014 | 04:34 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Can you buy bolts with the special hole drilled thru the threads for a castle-nut? It's a necessary safety feature to keep the suspension from flying apart if the nut should try to vibrate aloose from a bolt with no castle nut or cotter pin installed.....
Old Mar 7, 2014 | 05:13 PM
jr73's Avatar
jr73
Like
Old Mar 7, 2014 | 05:19 PM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Old Mar 7, 2014 | 05:55 PM
Trae1976's Avatar
Trae1976
Mine did not, they had nylon lock nuts instead. They haven't budged after 4 years.
Old Mar 7, 2014 | 06:08 PM
AirborneSilva
Yeah the bolts that I've seen (and I've only looked at one), sold by a vendor is the same, uses nylon lock nuts.
Old Mar 7, 2014 | 11:58 PM
3JsVette's Avatar
3JsVette
You nailed it. Great stance.
