Trivia
Old Mar 27, 2014 | 07:10 PM
Jack605's Avatar
Jack605
Default Trivia
What engine goes with a 5500 red line on the tach
Old Mar 28, 2014 | 12:04 AM
7T1vette's Avatar
7T1vette
None, at 5500 rpm that I know of. L-36, L-68, and the 1971 LS-5 engines had a redline of 5400 rpm; the L-46 and 1972 LT-1 engines had a redline of 5600 rpm.
If there is one with a 5500 rpm redline, what is it?
Old Mar 28, 2014 | 11:14 AM
Jack605's Avatar
Jack605
Wilcox has just finished with my gauges so I will re-check the red line on the Tach when I get it back.
Old Mar 28, 2014 | 11:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
How is that trivia?
Old Mar 28, 2014 | 11:37 AM
Les's Avatar
Les
The L36 redlines at 5600 and the L68 should be the same since it is the same valvetrain but has the 3 deuces. LT1 redline should be above 5600 since it shows that RPM as the power peak but I don't have time to verify that.
Old Mar 28, 2014 | 05:33 PM
7T1vette's Avatar
7T1vette
5600 rpm for the 1972 LT-1. The prior year's LT-1 engines had higher redline specs.
Old Mar 29, 2014 | 01:12 AM
Les's Avatar
Les
Yes, I understand that we are talking about a 1972. However, the 5600 RPM redline that you referred to only applies to the LT1s with A/C- the non-A/C LT1s had a redline of 6500.
The reason is stated here- http://www.vettefinders.com/index.cf...ifications.htm
And here- http://forums.corvetteforum.com/c3-g...972-lt1-2.html
And the difference is mentioned again here- http://forums.corvetteforum.com/c3-g...r-spotted.html
Any further discussion on those two bigblocks?
Old Apr 14, 2014 | 01:31 PM
Jack605's Avatar
Jack605
Default 5600 rpm
Just got my gauges back, the tach red lines at 5600rpm.
Old Apr 14, 2014 | 01:44 PM
Easy Mike's Avatar
Easy Mike
So what is the answer to your 5500 rpm question?
Old Apr 14, 2014 | 02:38 PM
Jack605's Avatar
Jack605
I admit to not having an answer.
Old Apr 14, 2014 | 03:04 PM
Easy Mike's Avatar
Easy Mike
That's trivial.
Old Apr 15, 2014 | 11:08 AM
7T1vette's Avatar
7T1vette
....but HONEST!!!
If the '72 tach for the LT-1 was set at 6500, so be it. But, I'm not sure the '72 LT-1 engine would actually wind that high.
My info (unofficial) indicates that peak power for the '70 LT-1 was at 6000 rpm; for '71 at 5800 rpm; and for '72 at 5600 rpm. I guess the 6500 redline was just a marketing ploy...
Old Apr 15, 2014 | 11:37 AM
Revi's Avatar
Revi
68 l-36. (L thirty six)
For some reason an upper case "L" cannot be typed with a dash(-) or number next to it?
Old Apr 15, 2014 | 11:51 AM
Mike Ward's Avatar
Mike Ward
L-36
Old Apr 15, 2014 | 12:45 PM
Les's Avatar
Les
....but HONEST!!!
Is that the same source that says the L36, L68, and 1971 LS5 all redline at 5400 RPMs?
Old Apr 15, 2014 | 01:23 PM
Revi's Avatar
Revi
Originally Posted by mike ward
l-36
68 l-36
Edit: Notice in my reply that both your and my "L's" are upper case, but both appear as lower case after clicking on Submit Reply.
Old Apr 15, 2014 | 01:24 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by Revi
68 l-36
Llama
To Trivia
Old Apr 15, 2014 | 04:16 PM
7T1vette's Avatar
7T1vette
My initial response on this thread indicates the redline data I have for those engines. So, NO, they are not all 5400 rpm.
What....EXACTLY....is your problem?????
Old Apr 15, 2014 | 05:13 PM
Les's Avatar
Les
My EXACT problem is that you continue to put out inaccurate info. It misleads folks who don't know the correct answers. If you don't like to be corrected, make sure your info is true before you post it. Simple, no?
Old Apr 15, 2014 | 08:42 PM
7T1vette's Avatar
7T1vette
You must be one of the ELITIST NCRS members. There are many who are not, but your attitude demonstrates that you are in that 'mold'.
I couldn't care less what you think or what you profess. None of us are perfect. But, you THINK you are...
