Vacuum question
Old Apr 6, 2014 | 06:27 PM
1978vett's Avatar
1978vett
Default Vacuum question
I have 2 nipples for port vacuum on my quadrajet,, is it possible at idle for one to have more vacuum than the other ,??
Old Apr 6, 2014 | 09:41 PM
7T1vette's Avatar
7T1vette
A ported vacuum fitting should have almost no vacuum on it at idle. That's the intent of the ported line. Vacuum should be almost nil at idle, but approach the same level as manifold vacuum once the throttle has been opening a bit.
But, in reality, I'm sure the vacuum level at idle for different 'ported' fittings would be a bit different. (But both should be at a very low level of vacuum.)
Old Apr 6, 2014 | 10:12 PM
1978vett's Avatar
1978vett
Thanks for your reply, I was just wondering about that, I think the other one must be manifold vac. ,, I can feel it at idle.. I thought it was ported vac. because it was about the same height on the carb as one that I am sure is ported.. A little confused..
Old Apr 7, 2014 | 02:08 AM
7T1vette's Avatar
7T1vette
The location on the carb body doesn't really tell you anything. The sources for all of the vacuum nipples originate at the primary throttle bores in the throttle plate; internal passages in the plate and the carb body can transfer each source to about anywhere on the carb.
The only way to really know is to put a gauge on each fitting and measure vacuum at idle and then watch it as you slowly/gradually crack the throttle, or if you have a guide drawing provided by the carb manufacturer.
On most Q-Jets, the right-side port coming through the choke mechanism is manifold vacuum, as are the rear-center [large] port intended for the power brake booster and the front-center port that is intended for the PCV purge line. The two ports from the front of the carb body are both ported vacuum, I believe.
Old Apr 7, 2014 | 09:00 AM
1978vett's Avatar
1978vett
The two ports from the front are the ones I was wondering about... I was thinking they were both ported but I can feel fairly strong vacuum coming from the one on the right ,,
Old Apr 7, 2014 | 01:28 PM
7T1vette's Avatar
7T1vette
If you NEED ported vacuum for something, use the one that has less vacuum at idle....AS LONG AS IT HAS GOOD VACUUM WHEN YOU CRACK THE THROTTLE.
AFAIC, the only "good" use of ported vacuum is for the line going to the fuel vapor recovery canister which signals the can to 'purge'.
Old Apr 8, 2014 | 10:05 AM
1978vett's Avatar
1978vett
Thanks for your reply,,, One of the hoses that runs to my vapor canister isn't connected to a vac. source .. The end that is connected to the canister is connected to the port that says control vacuum on the canister.. So do you think that hose should be connected to ported vac. at the carb ? Thanks for any info..
Old Apr 8, 2014 | 10:42 AM
7T1vette's Avatar
7T1vette
The 'control' port on the vapor canister should be connected to a "ported" vacuum nipple on your carb. That will cause the canister to purge only when the car is above an idle condition. The 'inlet' (or IN) line should be coming from the fuel tank and the 'output' (OUT or PURGE) fitting should be connected to the top side of the PCV valve with a T-fitting. The other side of that T-fitting runs to the large port at the front of the carb base plate. That's where the vapor fumes are directed (along with PCV valve output) for getting into the fuel charge for burning.
Old Apr 8, 2014 | 01:28 PM
1978vett's Avatar
1978vett
Thank you very much for your reply .. Looking at the length of the hose I would guess that it was connected to manifold at one time.. I'm not sure how that would work out ,,,
Old Apr 8, 2014 | 08:32 PM
7T1vette's Avatar
7T1vette
An A.I.M. for your model year car will detail all of the correct hoses, fittings, and connections.
To Vacuum question
