My beautiful 68 dash!
Old Apr 14, 2014 | 08:15 PM
AWilson's Avatar
AWilson
Default My beautiful 68 dash!
Im getting close guys! Should have it all installed in the next week or so. All the panels and bezels are original of which I restored! It actually looks much better in real life. Camera glare, etc!
What do you think!
Old Apr 14, 2014 | 08:18 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
Default 68 Dash
Looks great!
Old Apr 14, 2014 | 08:23 PM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
Careful putting the gauge cluster back together, that pesky oil pressure line breaks very easy if you have the original....
Trust me, I know.
Looks awesome, great job.
Old Apr 14, 2014 | 08:30 PM
Lupigiato's Avatar
Lupigiato
I'm thinking of sending my dash and instrument panels to you for restoration - LOL! How did you paint the panels and keep the chrome trim clean? Well done!
Old Apr 14, 2014 | 08:40 PM
AWilson's Avatar
AWilson
You can get paint from the parts houses, they call it dye, but it is paint. But it does not crack as the panels are not that flexible. But the paint with the closest match as per the forum is Krylon Industrial number 1610 which is what I used. It is very hard to find as you have to find someone who can get it wholesale and it is still difficult.
Prepping the bezels involved prepping them by sanding smooth including sanding or razor blading any pitting down. Then painting them a couple times and then sanding till the pits are filled. You have to use the finish paint not primer for this other wise the next step will not work as you will scrape through to the exposed primer. Maybe black primer would work.
As for keeping the chrome clean, you don't. You just spray it all, wait an hour or so and then take a razor blade and carefully scrape the paint off the chrome you want exposed. It scrapes a very fine line and looks great. I read about it on the forum, didn't believe it would work, tried it, and its just fine. UNLESS the exposed chrome is pitted. Then you have trouble. Fortunately I had little to none of that.
That is how I did it. Maybe there are better or easier ways. But that is what I did.
thanks!
Old Apr 14, 2014 | 09:06 PM
DZRick's Avatar
DZRick
That all looks fantastic, nice job!
Old Apr 14, 2014 | 09:23 PM
ctuinstra's Avatar
ctuinstra
I LOVE the key in the dash!!! That's something that you and I have that many of the others don't. I love reaching up and turning the key. The column key is so common.
You dash looks great! That is really going to dress up the interior.
Is the only thing you did to the chrome is razer the pitting? I wondering what I should do with mine, strip it and get it re-chromed and then paint it?
Old Apr 14, 2014 | 09:32 PM
AWilson's Avatar
AWilson
To me the deciding point is if the area of the chrome that you razor has pitting exists. If it does than obviously that will show.
Old Apr 14, 2014 | 09:37 PM
69bones's Avatar
69bones
St. Jude Donor '14
It looks great! I would love to dye almost my entire interior to get it back to one steady tone of it's original 69 saddle.
I wished the 69 would have kept the key in the dash too....I think it's much more 'hot rod' there.
Old Apr 14, 2014 | 11:15 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Absolutely Positively Inexplicably (spell-check is great) kool!
Old Apr 15, 2014 | 07:02 AM
bkvette3's Avatar
bkvette3
Nicely done - looks great!!! BK3
Old Apr 15, 2014 | 07:10 AM
tokim's Avatar
tokim
Nicely done, looks great!
Old Apr 15, 2014 | 07:43 AM
Alan 71's Avatar
Alan 71
Hi AW,
The parts look terrific!
A tremendous amount of work represented in those pictures!
Regards,
Alan
Old Apr 15, 2014 | 07:48 AM
twinpack's Avatar
twinpack
Your work looks awesome. I pretty much did the same with my 68 dash but my center bezel was broken like most and had to be repaired. Is the shifter boot original or did you buy a new one, if so please tell me were you got if from. It appears to have the correct number of folds.
Old Apr 15, 2014 | 07:54 AM
MuskieAL's Avatar
MuskieAL
St. Jude Donor '15 thru'19,'23 thru '26
Aw,
Looks great! Maybe one day over the summer, I can put my top down and drive over to have a look. Very well done....
Old Apr 15, 2014 | 09:37 AM
68Thunder427's Avatar
68Thunder427
It looks great and I wish I would have seen this earlier I just redid all of my dash panels, lights etc. I had no idea how to tackle the center console aluminum pieces but now I know and guess I will take mine back apart. Great job again though.
Old Apr 15, 2014 | 10:29 AM
682XLR8's Avatar
682XLR8
Looks real good
My metal console pieces are due for a remove/restore, this gives me some incentive to get busy
To My beautiful 68 dash!
Old Apr 15, 2014 | 10:37 AM
7T1vette's Avatar
7T1vette
Vinyl dye is NOT paint. It is a member of the 'paint' family; but it has significant differences from regular paint.
It is flexible; it is very thin in consistency; it is very dense in pigment; it leaves a very thin but well colored layer which bonds to the [plastic] parts; it will not peel or chip when dry; it does not fill-in part surface grain--even with multiple color changes and layers of dye.
I only state this to refute your comment about it being paint. If you "paint" your interior parts, you can NEVER AGAIN get the benefits of any dye you put on later.
BTW, if your 'dye' went on like spray paint---they sold you spray paint with the word 'dye' in the label.
P.S. Your work is terrific! I hope that you were sold dye, rather than paint.
Old Apr 15, 2014 | 06:11 PM
loup68's Avatar
loup68
Army
You are so fortunate to have a non broken center bezel. You did some beautiful work there! The 68 only shifter boot is available, ZIP sells them, that is where I bought mine from. Lou.
Old Apr 15, 2014 | 08:25 PM
Brandons72vette's Avatar
Brandons72vette
Looks very good, I am proud of ya!
