Ventilation question
In the cabin, there are two center console levers with a round "Close" head. These control what appears to be fresh air vents behind the kick panels by a cable. Simple, manual system. I assume it is isolated from everything.
There is also the Astro ventilation system. Are these ONLY the round vents or do other vents receive this air? These appear to also be manually controlled with a black push pull button. Are these involved in the AC system at all?
Then there are the two long slotted vents on the passenger side. Are these part of the Astro system?
What doesn't help here is this car did not have AC and someone installed an after market one. Not sure if the vents are hooked up like for a normal AC car or Bubba'ed together.
Thanks for any help.
LarMan
Houston, TX
On C3s, with the dash vents open, outside air enters through the kick panel doors and the dash vent *****. In theory, air leaves the car through the rear bulkhead doors and the vents on the rear deck.
Closing the vent ***** on the consoles closes only the kick panel doors. To stop air from the dash vent *****, you have to turn the vent *****.
There's a blurb about Astro-Ventilaiton in the owner's manual.
In order for the air that enters through the kick panel vents and 'astro-ventilation' ***** to have a place to flow with the windows closed, there's a pair of vents under the rear deck on coupes, and on the rear bulkhead on convertibles.
These vents have 'flapper' doors that are controlled by the Hot-Cold wheel on the right side of the heater defroster control on the console.
Vacuum is used to open the flapper doors when the wheel is turned to cold. If the doors aren't opened the air flow into the car is restricted.
On a/c cars these rear vents are blocked off permanently.
Regards,
Alan
The after market AC blows very cold air on the passenger's legs but none on yours truly. Hmmmm. I wonder if I could direct some of that nice cold air to the Astro vent on the drivers side. (Don't cringe... it is already non original on many levels. )
Thanks for your help.
