Correct Rochester?
http://www.ebay.com/itm/1970-chevell...-/331191699529
Stamping looks correct ....just my opinion
Will it run good ...did person rebuild it correct , sometimes people use wrong parts, like bases .? That's speculative .
It's expensive and you might still need to get it retuned if it doesn't run the engine good.
Sometimes you just gamble
Why would the seller only post pre restoration pictures and not what it looks like now?I will say that, in the pictures posted, it has the wrong air horn (or top plate).
I have a sb, so I've never shopped for a bb carb ... price seems high. Unless the carb you want is rare, I'd look for an unrestored one and send it to Lars.
You could also ask the seller if you could buy it unrestored (if that's the case).
Please let us know what happens.
Good luck.
That's correct: The carb pictured in the ad does not have the 1970 airhorn: The correct airhorn has an idle vent hole covered by a 2-piece reed valve that's connected to the accel pump lever with a metal wire. All of those parts are missing, and the airhorn does not have the vent hole in it - it's the wrong part...
But I see that none of this bothered somebody who bought the thing... the carb is sold, and it's messed up... good luck to somebody.
Lars
it is hard to find expertise on what is the exact base plate, air horn, linkage setup and what a restamp looks like. different carbs will have different vacumm and venturi ports.
what is exactly correct for your specific date and year is really hard to say. but for 1200+ you want correct in every possible way and I would get agreement from as many people as you can consult before giving up that amount.
Add also to the fact that this would be about a 60+ days old carb for your car.. approaching the extreme date spread that would be acceptable for your points judging.
also looks like it is missing the decell valve.. a rare and expensive part of that carb that you will lose points on.
check this page for extremely limited info on a supposed correct carb
http://1970corvetteregistry.org/mechdetails.html
Here's another carb that went for 1/2 the one you are looking at.. it is more correct than the one you are looking at? I dunno...
http://www.ebay.com/itm/ROCHESTER-QUADRAJET-7040205-EH-CORVETTE-CHEVELLE-MONTE-CARLO-CAMARO-/181312250734?pt=Vintage_Car_Truck_Parts_Accessories&hash=item2a370d636e&vxp=mtr&nma=true&si=e%252F2%252FFVB%252FqdrvvWRNRIkk8DNa2eo%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
