Question about "Matching Numbers"
I'm going to be starting a project soon and I have a question. The first of many to be sure!
The car is a 1 owner '69 vert that's been sitting in a garage since the late 70's. The first thing I want to start on once I get it will be the brakes.
I assume the brake calipers are not SS sleeved since they are original. Is this a correct assumption? And if so, do the calipers have any kind of date stamp or code on them? Do I need to get my current calipers sleeved to maintain the originality of the car, or can I replace them without worrying about ruining the "numbers matching" aspect of the car? I was planning on just rebuilding the existing master cylinder. It's a manual brake car so no worries about a power booster. And what about brake lines. I haven't had an opportunity to crawl under the car and look at the existing lines, but was planning on replacing them with SS brake lines and braided flexible hoses. Any problem there? I'm not planning on trying to achieve any NCRS certification or anything, but I would like to keep the car as original as possible. Also, anything else I need to worry about as far as the brake system goes? Anything I need to keep with the parking brake? Any insight anyone can provide is greatly appreciated.
Original calipers were not stainless steel sleeved.
Stainless steel brake lines and braided hoses are not original and neither is necessary.
Pricey, but nice to have:
CSS will sell you the correct casting already rebuilt.
http://www.cssbinc.com/1965-1982stai...frontleft.aspx
Good luck with your '69!
Regards,
Stan Falenski
Fact is, he HAS his originals. Why not send them out and get the same ones back?
Agreed.
One of the best books you could own as a '69 owner. I only wish that the photos were a bit larger, in color, and more detailed. They originally sold for around $70, but well worth the money in my opinion.
Regards,
Stan
Re: "matching numbers"... there is a difference between numbers that "match" (i.e. the engine pad VIN matching the body VIN) as opposed to numbers that are "correct" (part numbers or date codes that are appropriate for a car, but have no specific VIN that matches anything, and therefore are easily obtained).
Even though you're not thinking NCRS at this time, I'd suggest the NCRS Technical Information Manual & Judging Guide might be of interest and use to you as you proceed with your project.
It's available on the NCRS web site in the "Store'.
You can never tell… you might just catch the bug!
Regards,
Alan
I did contact Bair's and they will sleeve rebuild my existing calipers for less than most of the replacement calipers. 3 to 4 weeks later I get MY calipers back all sleeved, rebuilt and pretty! :-) I just have to look in to shipping now, but it'll cost a pretty penny to ship something that heavy...
I assume the brake calipers are not SS sleeved since they are original. Is this a correct assumption? And if so, do the calipers have any kind of date stamp or code on them? Do I need to get my current calipers sleeved to maintain the originality of the car, or can I replace them without worrying about ruining the "numbers matching" aspect of the car? I was planning on just rebuilding the existing master cylinder. It's a manual brake car so no worries about a power booster. And what about brake lines. I haven't had an opportunity to crawl under the car and look at the existing 0lines, but was planning on replacing them with SS brake lines and braided flexible hoses. Any problem there? I'm not planning on trying to achieve any NCRS certification or anything, but I would like to keep the car as original as possible. Also, anything else I need to worry about as far as the brake system goes? Anything I need to keep with the parking brake? Any insight anyone can provide is greatly appreciated.
