Tire size?
Old May 14, 2014 | 07:54 PM
CAN-AM69's Avatar
CAN-AM69
Default Tire size?
The tank sticker says F70 x 15 white stripe and the tires on the car now are P235/70 B 15. What should they be?
Old May 14, 2014 | 08:06 PM
gbvette62's Avatar
gbvette62
P215/70R15 is the metric equivalent of the OEM F70x15 tire. A P235/70R15 is equal to a H70x15.
Old May 14, 2014 | 08:11 PM
Alan 71's Avatar
Alan 71
Hi CA,
The present day equivalent of the F70-15 tire is a 215-70-15 tire.
This tire is very close to height and width of the original.
By today's standards it looks a bit skimpy because the present tire has 'rounded' shoulders, while the F70 tire has very 'square' shoulders which fill the wheel well opening a bit better.
Many people use a 225-70-15 tire which gives a good appearance.
Your present tire is close to that, (it's a little taller and wider), and might be fine for your situation and tastes.
Regards,
Alan
Old May 14, 2014 | 08:18 PM
CAN-AM69's Avatar
CAN-AM69
Thank you gbvette62. I wondered what the first numbers should be.
Old May 14, 2014 | 08:20 PM
CAN-AM69's Avatar
CAN-AM69
Originally Posted by Alan 71
Hi CA,
Your present tire is close to that A little taller and wider) and might be fine for your situation and tastes.
Regards,
Alan
Thank you Alan. The tires on the car now look good and they do fill the wheel well nicely but I think they might be a smidge too big....I'm afraid they might rub with a hard turn.
To Tire size?
