Oh boy...
Last night, turned the ignition key on and hit the blower switch and nothing happened. WTF? It worked before I installed the heater control unit when it was loose and now it's buried in the center console. I twist the heater control carefully, so I can pull the blower switch harness and it's a tough deal to pull it off, because it's underneath the control unit. I check it and no voltage on anything. So, with the probe, I started running down the schematic and got to the point, where the harness for the power enters the heater control from underneath on the left side, through a brown wire! It looks skewed for some reason, but I can't get to it, because it's underneath and inside the heater control! Completely surrounded by sheet metal and plugs in upside down going straight up.
Now I have to pull the heater control, to find out! But I don't want to pull the console either and the steel cable for the right thumb wheel is preventing it from pulling back and up. Can't get a socket or wrench on the bolt that holds the cable to the heater control, but I get a bright idea. I go to the flapper door itself, on top of the air box on the passenger side. I'll disconnect the cable there! But I've got the front duct already in place and can't pull that, without pulling the center gauge stack, but there's barely enough room on the right side, to fit my hand in there and disconnect it. But I manage to do it. It wasn't easy, but now I can slide the heater control back.
Now it's got reluctant slack and the heater control comes back a little, but I have to pull the main plug for the vacuum lines, because they're limiting the movement. I get that off and pull the unit, reluctantly back and out, so I can check the voltage on the underside, where the brown wire, that carries the power wire goes in.
I turn the key on and I get 12.6 volts. I'm an hour into this already. So I check the blower switch. Nothing. Then I look at the schematic that Wilcox had, that was far more accurate than the factory one and notice a 'master switch'. What the heck is that? Then I remember the reed switch on the side, that's controlled by the left thumb wheel and rotate it to AC and suddenly the blower comes on!
I rotate it to Heat and Def and the blower is coming on. There was nothing wrong to begin with! Unlike modern cars (like my Focus or my C4, where the blower switch always works, no matter what position, the left side thumbwheel has to be moved from "Off". Aaaaugh!!!!
So I spent another hour and a half, buttoning it all back up together!!! Two and half hours for NOTHING! Where is the gasoline? The matches? I coulda had the dash buttoned up by now!!! So instead of a second beer, I had a margarita instead, after I had finished putting it back together. Damaged nothing in the process and sure learned a lot...Gawd...
:cr azy2:
Experience: Something you get 15 seconds after you need it.
Just feel good about the learning process. Can't tell you how many times I've taken the same thing apart because I missed something in the re-assembly.
Grab a beer and try again later.
Good luck!!!
K
Well.........now it works(worked) correctly(in the first place)........
and you saved me 2 hours of getting faster at removing my dash!
We have a BUNCH of other great local cruises planned and more in the planning stages.....
If you don't make this one, there's another coming right up!
Here's one on July 12th
http://forums.corvetteforum.com/c3-g...a-highway.html
Here's one on August 2nd
http://forums.corvetteforum.com/c3-g...tunes-net.html
I don't have car's user manual, and I just don't understand anything to the climate control unit. I should because I will soon wrap up the interior, better make sure the blower works as it should.
Jeff, I'm making it! I'll be there in Santa Monica, barring any unknown problems with having a brand new dash harness, heater control rebuild, custom stereo install and a new (not rebuilt) alternator.
Keith, you're right on about experience. Sheesh! It's like the 'Tribal Knowledge' thing. For example, the same Gen1 SBC now has two different oil pans! From 76 or 77, they made the gasket 'deeper' at the back, so if you use an early oilpan gasket on a newer SBC pan or the Milodon pans, guess what, you're gonna have a pretty good leak going. Ask me how I know!
And I'm being so careful, because this is the LAST FRIGGING TIME, I EVER WANT TO PULL THE DASH AGAIN!!! Thus, the Power Probe. It makes it so easy to check the bulbs. Hit the rocker forward for voltage from the battery, touch the socket, wham-o and you get instant verification. You can even test the bulbs in your hand! I think they're a little over a hundred bucks. Best $100 I ever spent. You get verification of grounds and even if you have to puncture the wire, you get a 'green' telling you the circuit is complete, once you touch that wire. For me, it's a 'gotta have' item.
http://www.powerprobe.com/
Also, if you're doing a lot of dash and interior work, it really helps to jack the car up on all four corners as high as you can get it. Makes it much easier to get in and out. Much easier to have your knees on the ground, while you're working under the dash.
Finally, I still love my PK Safety rubber mats! Two years old and they're still holding up like they were new! The big one is great for the knees on the concrete and laying under the car, the little ones go over the hand brake handle, so you don't get that special imprint on the side of your rib cage after long hours of bending over the trans tunnel. They're not dollar store cheap, but they are tough and very comfortable!
The comfort factor of working many days and hours in the car, is worth spending a C-note on. I have the large $73 dollar mat (24x36) and a couple of the smaller ones. The big mat, works really well on the wooden creepers too.
http://www.pksafety.com/ergokneel-ex...-mat-5032.html
I'm not trying to be a shill here, I just want you guys, not to have to suffer as much, working on these cars, because you might as well be comfortable, especially if you're past middle age (cough) like most of us!
Watch out for power probes. I have one and use it alot(best tool in the world for diagnosing inoperative power windows) but it will lie to you. It may tell you there is ground or power on a circuit but wont tell you if its hanging on by a thread and will go open with a load applied to it. Like I said, I have one and use it alot but sometimes a non-powered test light works better.
