78 Vette - A/C issue
Old May 24, 2014 | 06:25 PM
gbarrett's Avatar
gbarrett
Default 78 Vette - A/C issue
I just got my wife the 25th Anniversary Vette for our 25th Anniversary. Low miles, island car, 23k miles - been in a garage most of its life.
I've been working on the A/C trying to get it cool because it's hot here. I have replaced the compressor, evaporator, accumulator and all of the o-rings and seals. I did a vacuum leak-down and it's all sealed. I've loaded it with R134 and it gets cool. The accumulator sweats nicely and the low-side pressure is low (60) and the high is high (275 - if I'm looking at the right scale). The problem is that it gets cool, but not cold.
Any ideas?
Old May 24, 2014 | 08:10 PM
qwank's Avatar
qwank
2 things come to mind here. first, what is the condition of your fan clutch? you need a good amount of air going across the condenser to get the a/c really cold.
second, how much R134 did you put in? you only need about 80% of R134 compared to R12
Old May 24, 2014 | 08:36 PM
Shark Racer's Avatar
Shark Racer
60psi on the low side actually seems kind of high for R134a if I remember correctly.
Does it work better when you're rolling down the road?
Old May 24, 2014 | 08:37 PM
gbarrett's Avatar
gbarrett
Thanks for the reply. I've got about 32 - 36 oz of R134 in there. I'll check the fan clutch tomorrow. I found buried in another site a page that suggested these vettes need a pusher fan on the condenser for the R134. I know the temp gauge was showing hotter now that the A/C is running.
If anyone has any other thoughts on the matter, I'm always ready to learn! Thanks!!
Old May 24, 2014 | 08:50 PM
gbarrett's Avatar
gbarrett
According to this: http://tech.corvettecentral.com/2008...4-ac-retrofit/
60 on the low side is a hair high, but it will probably come down with a pusher fan, right?
Thanks for the help - if something else comes to mind, don't hesitate to mention it.
Old May 24, 2014 | 09:05 PM
BLUDICE's Avatar
BLUDICE
Check the hot water shut off valve to see if it's working. Makes a huge difference in the air temperature in the cabin.
Old May 25, 2014 | 06:24 AM
68conv455's Avatar
68conv455
Before you buy a pusher fan, open the hood and check the clearance with the hood open on the front of the condenser. There won't be much.
X2 on the water shut-off valve.
Old May 25, 2014 | 09:28 AM
SIXFOOTER's Avatar
SIXFOOTER
When I was researching this I read that the Condensor should be a cross flow unit so thats what I used. Depending on how stuck you are on originality, consider going to an electric fan setup like a Spall or the like, cleans up a lot of junk under the hood and you can use a controller for the fans to make them come on when needed
Old May 26, 2014 | 11:57 AM
gbarrett's Avatar
gbarrett
Hot water shut-off valve doesn't have a vac hose attached and it's passing hot water through it. Also, the fan clutch is questionable. When the engine is cool, the A/C is cold.
So, next question: Where does the water valve get its vacuum from?
Old May 26, 2014 | 12:07 PM
'75's Avatar
'75
There should be a vacuum to the valve when switched to max A/C.
Old May 26, 2014 | 12:09 PM
gbarrett's Avatar
gbarrett
Great, thanks for the quick reply. Currently there is no hose there so I guess I'll take the dash apart and see if I can find something missing where the other end would attach.
Old May 26, 2014 | 12:16 PM
qwank's Avatar
qwank
i would look around the engine compartment first before i go tearing the dash apart. you might need to look up from under the car. chances are the hose just popped off and is hanging down somewhere
Old May 26, 2014 | 06:46 PM
BLUDICE's Avatar
BLUDICE
Vacuum line goes from the valve to the top of the firewall where there is 2other lines also. From there it goes to the dash controller. Mines missing too, but I found part of it sticking thru the firewall. It's 1/8" white or yellow and it is more like plastic than rubber. I've not seen it sold fom any parts supplier - one member suggested using air shock lines - and I have some - looks like it could work. Is your hot water shut off valve metal or plastic - mine is black plastic.
Old May 26, 2014 | 07:13 PM
gerry72's Avatar
gerry72
Google 134a temperature pressure chart. What pressures you are seeing greatly depend upon the temperature and humidity at the time reading are being taken and air flow across the condenser. It seems to me you are overcharged unless you were doing this in a Central American rain forest at the height of summer or you had minimal flow across the condenser. When you have an air flow issue, you can run water over the condenser when charging to bring pressures in line. And it is always better to be a bit under-charged than over.
As far as reading the gauges, do not pay attention to the inner temperature rings. While useful in determining system efficiency, they are nothing but a distraction in most instances. Use only the outer PSI scale.
Old May 26, 2014 | 09:02 PM
gbarrett's Avatar
gbarrett
I'm pretty close to the central American location - I live on an island on the southwest corner of Florida - the only place south of here is Cuba - I'm about 90 minutes from Havana. It was well over 90 degrees with more than 90% humidity when I took those readings. Gotta love Florida.
The water shut-off on my car is metal. I'll check for a vacuum port on the firewall in the morning. Also, I'll run water through the condenser once I get the shut-off valve straightened out and if readings are still high, I'll bleed off some of the pressure.
Thanks for the help - y'all are the BEST!
Old May 26, 2014 | 09:13 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
For even better hot water control go to a big box hardware store and get a ball valve to put in the heater hose to REALLY turn off the flow through the heater core. Someone on the forum (search for heater hose valve) can give you specific parts to get but it's an easy fix. When heat is not needed, like never in your part of the world, just cut the water off to stop all hot water flow through your heater into the cabin.
This does not replace the factory valve. Just supplements it.
Old May 26, 2014 | 09:51 PM
'75's Avatar
'75
This is what I use in place of the vacuum valve. Just close it all summer and open it in the fall.
http://www.napaonline.com/Catalog/Ca...271_0361163975
To 78 Vette - A/C issue
Old May 27, 2014 | 12:31 AM
speedreed8's Avatar
speedreed8
did you also replace the orifice valve, it takes a different size for 134a...
Old May 27, 2014 | 07:22 AM
BLUDICE's Avatar
BLUDICE
I think the metal shut off valve has a larger vacuum line than the plastic one, but not sure. I keep looking around for a '78 that's stock or restored to take a look at there's, but haven't found one yet.
Old Jun 2, 2014 | 08:54 PM
gbarrett's Avatar
gbarrett
Finally fixed it. I hooked the shut-off valve to a full-time vacuum source and capped the lead through the firewall. The car gets cold now and the "Max" setting on the A/C works.
Thanks for the help. Y'all are the best!
