Under layment pattern?
Old May 25, 2014 | 03:43 PM
mardyn's Avatar
mardyn
Default Under layment pattern?
Anybody seen or have a pattern for the under layment for the carpet on a '73 C3? I'll (hopefully) be ready to start installing my insulation and carpet next week.
Is there even such a thing available?
mardyn
Old May 26, 2014 | 09:12 AM
Alan 71's Avatar
Alan 71
Hi m,
Do you mean the pattern for the original underlayment or aftermarket?
Regards,
Alan
Old May 26, 2014 | 10:12 AM
DonnieP73's Avatar
DonnieP73
I just finished replacing the complete carpet on my 73. My carpet from ACC had all the backing on it.
I still have my old carpet that I could take a photo of if you really want that, but the backing on the new carpet was good enough for me.
Donnie
Old May 26, 2014 | 10:45 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Old May 26, 2014 | 11:58 AM
mardyn's Avatar
mardyn
I've got a 6 x 6 roll of bulk under layment I wanted to cut up
and use as I begin to reinstall y interior. I'm trying to get an idea
how the individual pieces should be shaped...
mardyn
Old May 26, 2014 | 03:05 PM
Alan 71's Avatar
Alan 71
Hi m,
The original underlayment was very intricately shaped and cut.
Although the original carpet wasn't that terrific it did fit/lay quite well and I guess the underlayment contributed to that.
Regards,
Alan
Underside of coupe left-side wheel-well piece.
Coupe rear compartment floor and bulkhead.
Passenger's side.
Old May 26, 2014 | 04:01 PM
mardyn's Avatar
mardyn
Thanks for the great pics...
Is the under layment (lightly) glued to the floor and trans tunnel?
Also, they recommended I install with the mastic side facing down..
I checked my new carpet this afternoon and the floor and back bulkhead pieces already
have jute style backing in place...
My thought is cut and cover similar to the above photo ^^ and then just lay the carpet on top using as little adhesive as I can get away with.
Any thoughts would be appreciated.
mardyn
Old May 26, 2014 | 04:47 PM
Alan 71's Avatar
Alan 71
Hi m,
I was trying to obtain an original appearance so used very little glue anywhere.
A few lines of it on the bulkhead right behind the seats, and a little in the driver's side foot-well in the area of the dimmer switch pad.
The rest is loose.
Regards,
Alan
To Under layment pattern?
