cleaning starter
Old May 26, 2014 | 05:58 PM
ernest3203's Avatar
ernest3203
Default cleaning starter
ok,waiting on new bolts for pressure plate because 400 flywheel has different thread than 350 so I pulled the starter apart,filthy with oil,grease etc,can I clean it with gas,brake cleaner,carb cleaner,then let it dry and put it back together,brushes look good
Old May 26, 2014 | 06:26 PM
7T1vette's Avatar
7T1vette
Yes. But gas is not the best thing to use, because it is flammable and more toxic to you. Simple Green or Purple Power and water will clean it just as well (use a small bristle brush). It's probably better if you open it up so it will dry more quickly.
I paint the housing semi-gloss black, the aluminum end piece with VHT aluminum paint, and the end plate with Dupli-Color engine enamel 'clear'. You might also want to check out the condition of the contacts in the solenoid...or rebuild it...or replace it.
Old May 26, 2014 | 08:05 PM
ernest3203's Avatar
ernest3203
thanks for the info starter is all apart just wanted to make sure cleaning it would not hurt the winding or anything else,never had a solenoid apart,i see theres 2 bolts ,is there anything that will fall out if i take it apart
Old May 26, 2014 | 08:22 PM
SB64's Avatar
SB64
Default starter
I have my starter sitting on my work bench all greasy and oily to. I have been using simple green so I am glad to hear that it can be used. Never took it apart so yes it would be nice to know if anything will come flying out or what to watch for.
R
Old May 26, 2014 | 10:35 PM
Mooser's Avatar
Mooser
Degrease with varsol, simple green, engine cleaner, etc.
[IMG][/IMG]
Blow everything apart, check the bushings and brushes. Wash it down with some electrical contact cleaner (OK I used brake cleaner) and blow it out with compressed air.
[IMG][/IMG]
you can lightly sand (400grit) the armature if it need it
[IMG][/IMG]
Sand & wipe it down with lacquer thinner, waz & grease remover, Pre-prep, whatever. Paint, powder coat, white grease into the bushings and on the pivots, slides, etc and back in business.
[IMG][/IMG]
M
Old May 27, 2014 | 06:10 AM
SB64's Avatar
SB64
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
M
Oh that came out real nice, I will look into that soon as I finish with exhaust manifolds. thanks
R
To cleaning starter
By Michael S. Palmer | 2026-06-03 09:39:05
