Rocker Nut Lifespan?
Old Jun 29, 2014 | 05:18 PM
Cavu2u's Avatar
Cavu2u
Default Rocker Nut Lifespan?
After a 30 min thread search with no luck, the question remains..
How long are the stock Rocker Arm Nuts on the SBC expected to last?
I just experienced the #1 Exhaust Rocker go loose after adjustment in only 4 miles. Really! Got that one replaced today.
Just wondered if there was a rule-of-thumb on replacing those guys.
Thanks in advance.
Steve
P.S.: Got a set of them on order.
Old Jun 29, 2014 | 08:28 PM
7T1vette's Avatar
7T1vette
Their lifespan has nothing to do with "mileage". It has more to do with how many times that nut has been removed/reinstalled or 'tweaked'. The Chevy nuts are intentionally deformed so that there is some interference on the fit. That is what keeps them from coming loose. Every time you work with one, some of that 'fit' is worn off. And, after enough adjustments, they get loose and will no longer hold.
I think they should be replaced after 3-4 "uses". But, that is for each user to determine.
{Or, you could just put a jamb nut on top of the 'loose' retaining nut. That will keep it in place.}
Old Jun 29, 2014 | 08:47 PM
Cavu2u's Avatar
Cavu2u
[QUOTE=7T1vette;1587247875]Their lifespan has nothing to do with "mileage". It has more to do with how many times that nut has been removed/reinstalled or 'tweaked'. The Chevy nuts are intentionally deformed so that there is some interference on the fit. That is what keeps them from coming loose. Every time you work with one, some of that 'fit' is worn off. And, after enough adjustments, they get loose and will no longer hold.
I think they should be replaced after 3-4 "uses". But, that is for each user to determine. [QUOTE]
To Rocker Nut Lifespan?
