Getting ready to put new door pulls on my new door panels. So before I make a mistake do I drill the holes straight or do I go in on an angel. I don't want to ruin them. Thanks
Hi tg,
The pulls have a top and bottom.
Make sure you have it the right way. Then insert a screw in each end and check to see at what angle the screw is, and then drill the holes accordingly.
Regards,
Alan
Hi tg,
Regards,
Alan
Top
Bottom
the holes should already be there at least they are on my 74
Hi tg,
Regards,
Alan
Top
Bottom
Those screws are a classic example of that particular screw, thread, length and even taper, that applies to that exact area and no where else! The C3 interior is FULL of screws like that! It's enough to drive a man mad! And good luck finding something like that door pull screw at a hardware store...
I believe that the holes for the 'pull' screws is drilled at an angle. Insert them in the original door panels to get a good idea of the angle[s] needed.
