71 LT1 Paint ?
Old Aug 8, 2014 | 08:11 AM
Mr Ski's Avatar
Mr Ski
Default 71 LT1 Paint ?
I am soon sending her in for paint
I am going to have it completely stripped and re-done
The gaps currently are not perfect but to me they look fine
Im told that they would have not been perfect 43 years ago
Body shop can of course add fiberglass and have all gaps perfect > Of course that would be more money
Part of me feels to do it, and part of me feels to keep it as it is
I do drive the car(limited), Im not looking for a show car only, but I will be spending alot of money and want it to look great
I value everyone's opinion so let me know your thoughts
Old Aug 8, 2014 | 08:28 AM
94hokies's Avatar
94hokies
Just talked with my painter about that this week. He said that if the gap at three of the 4 corners was even, that was close enough for it to look good. On my driver door, the rear gap is even but the front one slowly gets a bit bigger as it goes up. His opinion was that the cars came this way so there was no need to go to great measures to change it.
Old Aug 8, 2014 | 08:33 AM
Mr Ski's Avatar
Mr Ski
Thx for the reply
On mine for example, the top and the bottom of the door next to the front fender are tight and look good
The middle of the door to the front fender is however wider
Around the hood is widish, but more or less consistent all the way around
Decisons, decisions!
Old Aug 8, 2014 | 08:48 AM
Lobzila's Avatar
Lobzila
Depends on what there going to charge you for it. Say the total is 5k for the total strip and repaint, and for another 1K, it could be perfect. Mine had multiple hits over its 46 years and some good repairs, some not so good. Most all of them had to be redone and the guy working on mine was pretty **** about making all the panels fit better than when it left the factory. But when the paint gets stripped off, will the body shop find some hidden surprises that need attention? Hard call to make and good luck with your paint job.
Old Aug 8, 2014 | 10:48 AM
gbvette62's Avatar
gbvette62
Now is the time to make the gaps perfect! If you decide later, that you want them right, you're stuck.
If you do them, and they're perfect, most people will never even notice them. Unfortunately, if the gaps aren't perfect, especially on a quality paint job, they'll likely be pretty obvious.
Actually, I'm a little surprised that the shop is willing to do a car, and not make them perfect. Most of the Corvette shops I know, wouldn't do a paint job, without doing the gaps. It reflects on them and their work, when a car leaves their shop, and it isn't done correctly.
It's easy for me to sit at my keyboard, and spend your money, but if it was me, I'd want the gaps right.
Old Aug 8, 2014 | 11:19 AM
blueray72's Avatar
blueray72
Making the gaps perfect could mean so many things...is it a realignment of the doors or does the front clip have to be reset? I've learned that paint is really just a reflection of the work to the body. If you're not concerned about selling the car you can save a lot of money. If you're going to try and get top dollar for an LT1, the gaps have to be right.
Old Aug 9, 2014 | 11:45 PM
Zoomin's Avatar
Zoomin
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
If its worth doing, it's worth doing right.
Old Aug 10, 2014 | 11:07 AM
Alan 71's Avatar
Alan 71
Hi,
I think there's a "middle ground" here.
The fit of the doors/ hood (smooth transition from fender to hood/door) and the size and consistency of the gaps (hood/door) can be massaged to look like on THIS car the factory got it pretty close to 'right'.
Regards,
Alan
Old Aug 10, 2014 | 11:27 AM
persuader's Avatar
persuader
The gaps on my car were pretty much not acceptable in my opinion. Especially when I knew the level of paint work I wanted, So it was a no brainer for me to fix them. I rebuilt the hinges and adjusted the doors to achieve the best gap and then broke out the laminating stuff.
This is what I had pretty much on both sides. Even after many adjustments. The top gaps measured a around 1/2 inch!
After
Old Aug 10, 2014 | 02:27 PM
LT-1 kid's Avatar
LT-1 kid
71 LT-1 paint is special, not like a base L48 71.
Old Aug 10, 2014 | 05:31 PM
Alan 71's Avatar
Alan 71
Hi,
I believe the same paint was also used on LS6 cars.
It needed to be special because the rougher idle the 2 engines had would shake the normal paint loose from the body.
Regards,
Alan
Old Aug 10, 2014 | 11:12 PM
7007vette's Avatar
7007vette
I think Alan is right.
To 71 LT1 Paint ?
