Alignment?
Old Aug 11, 2014 | 12:10 PM
Snoopysvet's Avatar
Snoopysvet
Default Alignment?
My 1978 drives straight on the freeway however while cruising on the freeway if I take my foot off the gas it pulls a bit. Is that an alignment issue?
Old Aug 11, 2014 | 01:48 PM
MelWff's Avatar
MelWff
are you in the center of a multi lane freeway otherwise there are crowns that will cause drifting.
Old Aug 11, 2014 | 05:31 PM
Snoopysvet's Avatar
Snoopysvet
I was driving home and was in the middle lane most of the way home when I noticed it
Old Aug 11, 2014 | 06:33 PM
briankeery's Avatar
briankeery
Check your rear trailing arms, once you "unload" the drivetrain, they may have play in the bearings causing your 4 wheel alignment to change.
Old Aug 11, 2014 | 07:14 PM
gjohnson's Avatar
gjohnson
I agree w/the above post. From my reading the rear has a lot to do w/the tracking of the car.
Old Aug 12, 2014 | 03:54 PM
dochorsepower's Avatar
dochorsepower
Worn trailing arms will often cause it to dance/drift when you get on it. Either way it's time to talk to a good alignment shop. Not easy to find with an old Vette
To Alignment?
