Do I strip or Do I not Strip ?
Old Sep 5, 2014 | 06:01 PM
Burnt71's Avatar
Burnt71
Default Do I strip or Do I not Strip ?
How do I know if I need to remove all the paint from my project car to get ready to paint ? Do I just paint over the paint on the car ?
Old Sep 5, 2014 | 06:28 PM
John 65's Avatar
John 65
I wouldn't paint over the paint. No expert here, but play it safe and take it down to the bare glass and start from scratch.
Ya never know what you may find. Its a little work but worth it.
Old Sep 5, 2014 | 06:42 PM
Sunstroked's Avatar
Sunstroked
I guess there are those who advocate painting over the original paint. But I think it's kind of dumb. 40 + yr old lacquer paint probably isn't the best substrate for a new paint job.
Old Sep 5, 2014 | 09:30 PM
persuader's Avatar
persuader
For the best results it is always preferable to strip then paint.
Old Sep 5, 2014 | 09:33 PM
JVH's Avatar
JVH
What do you recommend for sanding the paint, what is the process, what grits of sand paper, da sander I assume also? Can someone list a step by step process from old paint to a ready to paint surface.
Old Sep 5, 2014 | 10:55 PM
94hokies's Avatar
94hokies
There are a bunch of threads on the topic and a whole forum area on just painting and bodywork in general here that I read through before getting started. Here is one of the threads that came up recently https://www.corvetteforum.com/forums...stripping.html
I described in more detail, but in short did the razor blade method on the paint and stripper on the multiple layers of primer under it. I used Citrustrip from Home Depot that I thought was good at the time. My painter gave me some aircraft stripper to take the lacquer off some rims and it ate right through it a lot faster than citrustrip ever did on the primer.
Anyway, head over to the paint and body forum and read through there for a while for all you should need to get started.
Old Sep 6, 2014 | 06:38 AM
zwede's Avatar
zwede
If it still has factory lacquer paint (or primer) it should be stripped. It's ok to paint over modern 2K paint.
I do not recommend a DA sander unless you really know what you're doing. If you don't you'll end up with ruined panels (wavy, thin and rounded edges/lines). I recommend you razor blade or use chem strip.
Old Sep 6, 2014 | 10:30 AM
augiedoggy's Avatar
augiedoggy
I agree with above... if its modern urethane paint and its not bubbling or peeling you would be fine sanding, sealing and painting... if its l aquer you need to remove it. I have my car half stripped with a razor blade and heat gun... it had been stripped before and I found a lot of repairs and evidence of three different colors... paint was bubbling from what I guess was evidence of a chemical stripper used in the past and not being properly neutralized?
Old Sep 6, 2014 | 11:03 AM
zwede's Avatar
zwede
Could be. Or something (like oil or brake fluid) got on the fiberglass before paint. Or they used incompatible primer/paint. Or just crap paint.
Old Sep 6, 2014 | 11:42 AM
540 vette's Avatar
540 vette
If it is the original paint and it is in good condition, scuff it with 400 and seal it with epoxy. Then paint. If you are not sure strip it. I use paint stripper for fiberglass. That is better than sandpaper or razors. Because you will not dig into the fiberglass.
Old Sep 6, 2014 | 11:53 AM
Burnt71's Avatar
Burnt71
old paint is in very good condition. putting a new front clip on
Old Sep 6, 2014 | 01:35 PM
Alan 71's Avatar
Alan 71
Hi,
Because of the work and cost involved in the finish coats of paint I think it's unwise to short cut the preparation in anyway.
Many people believe stripping the old paint with a remover is a good method that doesn't damage the surface of the fiberglass.
Since you really have no way of knowing what's going on with the existing paint, and can't see if some fiberglass repairs need to be done, until all the paint is off, I think stripping with something like Capt. Lee's striper is a wise decision.
Be careful where or how much you sand because it's very easy to end up with a body that has had the sharp creases and sharp corners sanded off.
I believe 95% of the work involved in painting a Corvette is in the preparation. It takes a lot of skill to do the actual painting but goes relatively quickly.
Regards,
Alan
Old Sep 6, 2014 | 02:48 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Normally I suggest Strip, but if you have had the car for a very long time and for certain know the history of the body,
with no spider cracking, no cracks anywhere, no paint problems, you have a solid base that probable would be ok to paint over.
Ultimately this decision needs to be made by whomever is going to paint it.
good luck
To Do I strip or Do I not Strip ?
