Getting started
Old Sep 6, 2014 | 07:21 PM
Jtsulli's Avatar
Jtsulli
Default Getting started
Hello everyone
When I go to start my 76 after a few days it takes a bit for it to fire
I pump gas first but that doesn't seem to help
I was wondering maybe the ignition should be on when I pump it
It just seems like its not getting fuel at first
I ask because I have an older 68 Torino and I pump it first and it starts thanks
Old Sep 7, 2014 | 02:32 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Before starting, remove the air filter housing, operate the carb linkage to see if you're getting a good squirt of fuel. Then looksee if the choke linkage is setting itself closed. Proper starting procedure: accel pedal to floor, release then halfway hold and start engine. If you don't see the a good squirt of fuel, maybe the carb is draining down. If that be the case you could try cranking the engine a bit to replace the missing fuel in the carb, then try the start procedure. Just some things to check. T
Old Sep 7, 2014 | 01:51 PM
20mercury's Avatar
20mercury
Default My 2 cents
My 2 cents, my 76 did the same thing, I replaced the fuel filter and that helped a lot.
To Getting started
