68 427 Coupe Trans question
Old Sep 11, 2014 | 02:33 PM
68bigblock's Avatar
68bigblock
Default 68 427 Coupe Trans question
I'm considering updating my 4 speed manual transmission to a 6-speed? This may be a stupid question, but will a T56 6 speed out of a 1990 Corvette bolt up to my 68 c3 427?
If not what 6speed trans do you recommend?
Old Sep 11, 2014 | 06:00 PM
jersey68l36's Avatar
jersey68l36
Doing a Google search, someone posted about such a swap. Can that trans hold up to 450+ft lbs of trq is another issue.
Old Sep 11, 2014 | 11:19 PM
7T1vette's Avatar
7T1vette
Put skinny tires on the rear and that amount of torque [and more] will not be a problem....
Old Sep 12, 2014 | 06:44 AM
Jamess411's Avatar
Jamess411
I cannot remember if the 90 Corvette uses the Torgue tube and has the trans mounted at the rear or not. If so it will be much more expensive to convert then to get one that is mounted at the rear of the engine like in a Camaro. Also some of the years had lower HP ratings…I think the 94-97 are the better ones. Do a search on the internet and read up on them to confirm. Research is your friend
Old Sep 12, 2014 | 11:00 AM
AirBusPilot's Avatar
AirBusPilot
I don't think it's a T56. It's a ZF.
Old Sep 12, 2014 | 11:14 AM
Jamess411's Avatar
Jamess411
Yeah thats it…the corvette has the ZF….was told when I did my first conversion to NOT use the ZF….the T56 is the right trans.
Old Sep 13, 2014 | 08:28 AM
pnewt's Avatar
pnewt
Default trans
A good source to ask that question would be Rodney at RPM Transmissions in New Castle Indiana.Acknowledged expert at this stuff. He'll be happy to help you out with advice. Good luck
Old Sep 13, 2014 | 09:45 AM
Garys 68's Avatar
Garys 68
As pointed out, the 90 C4 had a front mounted ZF, not a very popular trans. Any corvettes with a T56 will be a rear transaxle. You'll want to look into an f body LT-1 T56. Do not try to use the later LS1 T56.
You might be better off with a Tremec 5 speed from one of the aftermarket suppliers. A lot will depend on your rear end ratio and how you use the car.
Old Sep 13, 2014 | 10:08 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
To 68 427 Coupe Trans question
