wheels
Old Sep 14, 2014 | 09:26 PM
kevinll63's Avatar
kevinll63
Default wheels
I got a 77 with stock wheel I bought a set of aftermarket wheels that came off of a 70 vette the front rub the back of the tire when I turn if they fit the 70 shouldn't they fit mind the wheels came with 225 70 15 I had 255 60 15 on the stock wheels ?
Old Sep 14, 2014 | 09:51 PM
gbvette62's Avatar
gbvette62
Depending on the width and offset of the wheels, they might have rubbed on the 70 too. Maybe that's why the previous owner, sold them?
Old Sep 14, 2014 | 10:23 PM
kevinll63's Avatar
kevinll63
They are 8" wheels the same as the stock ones was going to put the 255 60 on the aftermarket wheels but I guess I will do some checking on the offset first
Old Sep 14, 2014 | 10:34 PM
Zoomin's Avatar
Zoomin
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Are the ride heights the same?
Old Sep 14, 2014 | 10:44 PM
kevinll63's Avatar
kevinll63
Don't know if they are the same height It is the lower part of the fender that rubs the tire when I turn
Old Sep 14, 2014 | 10:57 PM
qwank's Avatar
qwank
I bet they are the wrong back space. probably 4.5''
Old Sep 14, 2014 | 11:00 PM
gbvette62's Avatar
gbvette62
70's actually sat slightly lower, than 77's. The 68-72 Corvettes used solid body mounts, while 73-82 used rubber cushions, that raise the body some.
Where exactly is it rubbing? In your first post you say it's the "back of the tire", but your most recent one says the tire is rubbing on the "lower part of the fender"?
Old Sep 15, 2014 | 09:15 AM
parkerracing's Avatar
parkerracing
The bodies mfg. tolerances were VERY tolerant (throw in 40+ years of wrecks and repairs) and you can pull a set off one car and put them on another and they can rub. /:\
To wheels
