Can i please get some headlight help?
Old Sep 21, 2014 | 04:11 PM
Tooonz's Avatar
Tooonz
Default Can i please get some headlight help?
When we first bought this car, the headlight switch was completely bypassed and I was told that the switch under the steering column was how you put them up and then used the headlight switch to turn them on. I'm trying to right the wrong so I rerouted the hoses correctly but after getting the new engine in I found out the headlight switch would not lift the lights up only turn them on. So we ran the car mostly during the day for the first week, occasionally using the headlights a couple times. Those couple times, we just used the bypass to lift them, and the switch to turn them on.
Then as time went on one night we suddenly lost the headlights, not the light but they suddenly went down. If I pushed the switch in, they would come back up, pulled the switch back out, they would drop, not immediately but shortly after. At that time I could hear a vacuum leak sound at the switch when it was pulled on, the sound would stop when it was off.
So I bought a new switch, changed it out and still have the same issues. The only way to get the lights to open is the bypass, as soon as the light switch is pulled they close immediately. I've checked and rechecked the hoses and they all seem to be connected properly. Any help would be appreciated.
Old Sep 21, 2014 | 07:18 PM
DUB's Avatar
DUB
You have to be 100% positive...not "seem to be".
All I can write is that IF the hoses are correct...the system should work. I do it numerous times in a year. The two hoses that connect to your headlight switch need to be installed correctly.
I also verify that the vacuum switch that is made onto the headlight switch is working before I put it in. I ASSUME NOTHING.
This is also assuming that the actuator relays are good and the aluminum check valve off the intake vacuum is in good condition...so vacuum can be stored as designed.
DUB
Old Sep 21, 2014 | 08:09 PM
Tooonz's Avatar
Tooonz
Dub I say seem because it's still not working correctly. According to diagrams the hoses are connected correctly. I guess I'll have to start testing each piece separately , I did find a good article on trouble shooting, i guess it's not as easy as I hoped it would be. Now I know why they bypassed the light switch.
Old Sep 21, 2014 | 08:17 PM
firstvet79's Avatar
firstvet79
8th Gear
I have learned that in order to make lights go up you block vacuum to the control valves. According to the paper I received with my new hoses the vacuum supply goes to the back port of the headlight then from front port to the override switch. It does not take much of a leak to give you fits. I also bought a vacuum pump to test the actuators. Hope this helps.
Old Sep 21, 2014 | 08:20 PM
mds3013's Avatar
mds3013
Have you seen this? mike...
https://www.corvetteforum.com/forums...tem-works.html
Old Sep 21, 2014 | 08:41 PM
Tooonz's Avatar
Tooonz
When you guys push the over ride switch up, what happens? My lights open.
Old Sep 21, 2014 | 08:50 PM
mardyn's Avatar
mardyn
Reverse the hoses on the headlight switch... the assembly manual (at least the one I have) shows the hoses reversed from what they really should be.
Went through the same thing on my '73.
mardyn
Old Sep 22, 2014 | 06:16 AM
Street Rat's Avatar
Street Rat
The numerous Corvette vendors offer this manual. It may help you.
Old Sep 22, 2014 | 07:27 AM
Tooonz's Avatar
Tooonz
Mrdyn, I did switch the lines, didn't produce anything positive, I need to start testing hardware to determine the health of some items I guess.
Old Sep 22, 2014 | 09:39 AM
74Ken's Avatar
74Ken
I just saw a show on tv about this. They said that the NEW engine did NOT produce enough vacuum to raise the headlights. Maybe this is your problem.
You might need to install an electrical light system that I have seen people post on this forum.
Hope this helps.
Ken
Old Sep 22, 2014 | 10:58 AM
Tooonz's Avatar
Tooonz
Ken, I thought about that, but I do get the lights to open and close with the bypass switch, just when I add the lights, they close.
Old Sep 22, 2014 | 11:54 AM
widowmaker221's Avatar
widowmaker221
Sounds like your bypass and switch hoses are reversed?
Old Sep 22, 2014 | 12:16 PM
mardyn's Avatar
mardyn
Yeah, still sounds like there are some vac hoses switched in there somewhere... good luck on the search.
mardyn
Old Sep 22, 2014 | 12:59 PM
JimLentz's Avatar
JimLentz
When I had my dash out recently the lights worked find before I pulled everything apart in my '77. When I put it all back together I had the same symptoms you are describing and it was due to having the vacuum hoses switched on the headlight switch. If that is not it I believe it is the vacuum portion of the headlight switch is defective.
Old Sep 22, 2014 | 06:26 PM
DUB's Avatar
DUB
Tooonz,
Your vacuum hoses are not correct. That is what I am betting on.
When you pull DOWN on the override switch...the door open...push it back UP and they close.
IF you removed your headlight switch (for example) and joined the 2 hoses together....you would only be able to use your OVERRIDE switch to raise and lower for headlights.
The ONE thing that you have to remember.... and it is simple.... is that the SMALL hoses that goes to your headlight actuator relays is the CONTROL for raising and lowering your doors. The control of the vacuum is done by the headlight switch or override switch.
When VACUUM is added and taken away on this small hose...it moves a plunger in the relay...which directs the vacuum to the corresponding hose that goes to your actuator pods.
SO...I am betting that you have a vacuum hose routing problem..or a bad headlight vacuum switch.
Check EVERY hose...and ESPECIALLY those at the headlights.
DUB
Old Sep 22, 2014 | 07:24 PM
loup68's Avatar
loup68
Army
Dub, Do you know who is reproducing these headlight switches , and where? I take it that it isn't AC Delco anymore. Lou.
Old Sep 23, 2014 | 05:20 AM
Tooonz's Avatar
Tooonz
I tested the headlight switch last night, because I had just purchased it. It tested fine, The bypass switch tested fine. I tested the check valve and it won't hold vacuum steady, so I will order a new one, but I agree I think something is crossed somewhere. According to what I've read, if the check valve is bad headlights stay up, and ours don't. The check valve is just ever so slightly leaking, it will get replaced but my gut tells me that isn't the monster I'm chasing right now.thanks for all the help so far, it's helping me understand our corvette a little better.
To Can i please get some headlight help?
Old Sep 23, 2014 | 09:17 AM
Tooonz's Avatar
Tooonz
I reassembled the inside hoses this morning as I wanted to drive it to work, I left the bypass switch pushed up, started the car and the lights opened. pulled the light switch and they closed so no progress yet ( sigh ) I have the white striped hose connected to the white port on the bypass switch, that is connected to the relays. the line from the small port on the check valve is connected to port two on the headlight switch, and the blue port on the bypass is connected to port three. this is all according to a diagram I printed from the Willcox website. Will an iffy check valve be causing this?
Old Sep 23, 2014 | 09:36 AM
Dave J's Avatar
Dave J
Your headlights are reacting exactly opposite of how they should be. The only component that switches vacuum between the up and down cycle is the headlight relays. If the actuating hoses are reversed, the up and down cycle is reversed also. Double check the hose connections at the relays. Do not pay any attention to the hose color. Simply make sure the bottom hose on the relay is connected to the front of the actuator, and the top hose is connected to the rear of the actuator.
Old Sep 23, 2014 | 06:14 PM
Tooonz's Avatar
Tooonz
Dave define front and back of the actuators please if the front is facing the engine then they are correct.
