Hard Top Window Date Code
Old Sep 22, 2014 | 09:37 PM
SharkAttack's Avatar
SharkAttack
Default Hard Top Window Date Code
My hard top has "M72" as part of the markings in the lower left corner of the (back) window. I assume this is the date code? If so, can someone decode it properly? I've made a few guesses but want to confirm.
Old Sep 23, 2014 | 01:16 AM
jhudec's Avatar
jhudec
I did not think that was the date code. I thought the dat code was similar to the windshield/door glass. i.e. 2 alpha characters. like VT...........
Old Sep 23, 2014 | 07:38 AM
Alan 71's Avatar
Alan 71
Hi SA,
The 'M' and a number that you listed appears on all glass.
The number describes the glass.
For instance there is a different number for laminated plate, tempered plate, or tempered float glass, and for tinted or clear glass.
The 'M72' you found indicates 3/16", tempered, 'float' glass.
Regards,
Alan
Old Sep 23, 2014 | 09:07 AM
71 Green 454's Avatar
71 Green 454
Does the hard top rear glass have date codes?
When I had my headliner out many years ago, there were stamped dates on the inside of the headliner like the ones on the door panels.
Old Sep 23, 2014 | 11:06 AM
redrdstr72's Avatar
redrdstr72
Original glass did have date coding scribed into it. Look again at the information scribed in the lower left corner. The date (year/month) code will be depicted in 2 alpha characters. Post the characters here and we can let you know the date of glass manufacture.
Hope this helps.
Old Sep 23, 2014 | 11:26 AM
vettebuyer6369's Avatar
vettebuyer6369
Rear hardtop glass codes on my '69:
Old Sep 23, 2014 | 01:31 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Try this site. Take care, john
http://www.corvetteactioncenter.com/...3/c3glass.html
Old Sep 23, 2014 | 01:52 PM
71 Green 454
I see yours has CX, mine has CV. So it looks like yours is November, 1968, and mine is November 1969.
Old Sep 23, 2014 | 02:34 PM
Alan 71's Avatar
Alan 71
Hi,
The windshield logo and date code are interesting in that it was etched on the outside of the glass, but in reverse, so it's read from the interior.
You can just feel the etching with your finger tip or fingernail.
The AS1 was between the two layers of glass on the windshield.
Regards,
Alan
Old Sep 23, 2014 | 04:57 PM
71 Green 454
Originally Posted by Alan 71
Hi,
Regards,
Alan
I've owned my '71 for 39 years and today is the first time I have ever looked at my glass codes. I knew my hard top would be 1969.
For my April 19, 1971 build date, my glass codes are:
Left door, NN, Jan. 1971, etched on inside
Right door, IT, June 1970, etched on inside
Windshield, GN, April 1971, etched on outside in reverse.
Old Sep 23, 2014 | 05:17 PM
Alan 71's Avatar
Alan 71
Hi 71,
Interesting!
Your right-side door glass is likely an example of why the length of time before production is increased to 12 months for glass rather than the 6 months used for the vast majority of dated parts.
Regards,
Alan
Old Sep 23, 2014 | 09:53 PM
SharkAttack
Originally Posted by avalonjohn
Thanks John. According to this website, the "UT" code on my rear glass translates to July 1970.
Old Nov 4, 2021 | 02:39 PM
rod69ss's Avatar
rod69ss
2nd Gear
Default The 'M72' you found indicates 3/16", tempered, 'float' glass.
Hi SA,
Regards,
Alan
Hi Alan, Where does one find the M24, M72, etc. codes decoding information. Thanks, Rod
Old Nov 4, 2021 | 04:47 PM
71 Green 454
Hi Rod,
Alan hasn't posted since 2018. Here is a link that's been posted on this forum before that shows these codes. Scroll down about half way and you will see the decoding information for M24 and M72.
http://www.camaros.org/glass.shtml#marks
Also, here is a reference for LOF date codes.
https://www.corvetteactioncenter.com...3/c3glass.html
Old Nov 5, 2021 | 07:48 AM
rod69ss's Avatar
rod69ss
2nd Gear
Originally Posted by 71 Green 454
Hi Rod,
Alan hasn't posted since 2018. Here is a link that's been posted on this forum before that shows these codes. Scroll down about half way and you will the decoding information for M24 and M72.
Thank you. Very much appreciated.
Old Nov 6, 2021 | 12:01 AM
REDONBLACK69's Avatar
REDONBLACK69
71 green 454,
A little off-topic but, does your November 69 hardtop have a chrome, triangular, mounting bracket at the lower-center of the rear bow? A chrome carriage bolt passes through the bracket and through a ferrule in the center of the decklid, and acts as another mounting point for the hardtop. I'm helping to document when GM added this bracket to the hardtop. So far, information shows that it was sometime in late '69. The approximate serial number is unknown.
Oddly, on my '69, I have a '71 vinyl covered hardtop dated nn (Jan '71) that I bought many years ago. My car was built in November '69, just as your hardtop is dated. FWIW.
R on B 69
Old Nov 6, 2021 | 12:16 AM
71 Green 454
Yes, my Nov. '69 Hardtop has the center bracket with a carriage bolt.
To Hard Top Window Date Code
