Mystery Bracket?
Old Sep 27, 2014 | 08:47 PM
goodguys282's Avatar
goodguys282
Default Mystery Bracket?
This bracket that the fuel filter is attached to looks like there should have been something there. If you notice the fan pulley has a place for a third belt. This is a 69 350/350 non air car. Thanks in advance.
Old Sep 27, 2014 | 08:52 PM
76CSRvette's Avatar
76CSRvette
it could be an ac car? and or power steering and are they missing
Old Sep 27, 2014 | 08:54 PM
goodguys282
Originally Posted by 76CSRvette
it could be an ac car? and or power brakes and are they missing
Non air car.
Old Sep 27, 2014 | 08:56 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
That bracket the fuel filter is attached to is for the AIR pump.
Probably what the missing belt is.
early shark's Avatar
early shark
Looks more like a bracket for the air pump for emissions system (smog).
Old Sep 27, 2014 | 08:57 PM
76CSRvette's Avatar
76CSRvette
that's it A.I.R. pump bracket
Old Sep 27, 2014 | 09:10 PM
goodguys282
Thank you guys. So I can probably remove that since I'm not putting in an air pump.
Old Sep 27, 2014 | 09:24 PM
KapsSA's Avatar
KapsSA
If you're really fussy you can remove the pulley, too, it's an add on.
Old Sep 27, 2014 | 09:29 PM
goodguys282
An Add on? You mean like a 2 piece pulley? Also where would the filter mount if I removed that bracket?
Old Sep 27, 2014 | 09:38 PM
KapsSA's Avatar
KapsSA
Yep, single pulley mounted over a double.
Don't know about where to mount the filter.
Old Sep 28, 2014 | 05:56 PM
loup68's Avatar
loup68
Army
If you have the two metal lines for the filter and to the carb, you do not need to mount it. Lou.
Old Sep 28, 2014 | 06:34 PM
ScottE's Avatar
ScottE
This is where the stock fuel filter fits on the smog pump.
Old Sep 28, 2014 | 06:37 PM
goodguys282
Ok, that makes sense. Thanks
Old Oct 3, 2014 | 07:28 PM
David Mc's Avatar
David Mc
Don't throw it away. I restoration person may need it.
Old Oct 3, 2014 | 08:15 PM
goodguys282
Yes, thanks. I put it in the extra parts box. I don't throw much away. Just ask my wife
To Mystery Bracket?
