Spring Compressor
Old Oct 1, 2014 | 12:12 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
"tensile" oh you dare go there... That word cost me dearly in college.. It had something to do with a huge beer bet.. and how much our balsa-wood bridge would hold..
Turned out the guy with the 140 iq new more more than we did and the b'stard loved beer.. lol...
Old Oct 1, 2014 | 07:06 AM
Mooser's Avatar
Mooser
You remember something from college. I'm impressed
Ours was located right next door to a tavern......
M
Old Oct 1, 2014 | 01:23 PM
Haggisbash's Avatar
Haggisbash
Originally Posted by MakoJoe
By the way if anyone would like to harden the steel rods you bought from China all you need to do is heat them up with a Map Gas instead of propane gas on the same type of plumbing torch until they are really hot they do not need to be red hot or you will catch the oil on fire and dip them into conventional SAE 30W motor oil that you use in your lawn mower heck the used oil will probably work better since it has already been burned. The oil creates a hardened Carbon Coating on the threads which will change any Chinese made steel rod into a hardened steel rod or at least harden the threads I learned this stuff in High School Shop Class 30+ years ago
If the steel is too low in carbon content ie a "mild" steel this process wont work but if you would like to see the process in action take a high tensile bolt and heat it cherry red (it has to be cherry red not dull red) or the change wont happen. Then dip the bolt into a brine solution quickly, the end result will be a bolt so hard that if you put one end in a bench vice and smack the bolt sideways it will snap like a carrot ( safety glasses recommended)! Ahh yes blacksmithing and old vettes a perfect combo:-)
Old Oct 1, 2014 | 02:12 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
External spring compressor
Old Oct 1, 2014 | 05:52 PM
bj1k's Avatar
bj1k
While I partially agree with your thought the lower control arm will be lowered with a floor jack not using the tool I have built. In the procedure I will be using the tool is built to keep the spring from flying out from under the car as the floor jack does all the work. I will lower the control an inch or 2 at a time and do the same thing when installing the new springs and this tool will be used to hold the parts in place on reassembly while I reassemble the ball joints.
I do not go into what I am about to preform lightly and safety is my main concern.
I have read many stories where people have not used a compressor at all and just lowered the control arm with just a floor jack. I do not trust my floor jack to lower it slowly enough to be safe. So I will lower it then move the nuts to a safe position than do this multiple times.
The store bought spring compressors like this one are near impossible to install and remove out of the small hole at the lower shock mount.
http://htsmall.ecklerscorvette.com/a.../88-0152-1.jpg
The newer style outside spring compressors cannot be used because of clearance issues. Read this article from someone on the web that did a frame off and the problems he had to overcome. I will not have these problems because before I perform anything on my car I read about what others have done before me then use what they learned. If I can enhance it to fit my build I will because I am smart enough to look at it and say I can do it better than also safer.
http://mycorvetterestoration.com/196...p#.VCoNKvldXJc
I own the tool that you described from ecklers and just installed new springs in my 72 with no problems at all and have used this tool for many years in my restoration shop. They just take some getting used to when you install and remove the compressor parts. So much easier when you get used to it.
