'71 Coupe
Welcome!
The price you quote is at the lower side for a complete, running, 71 coupe in my mind.
Since you mention it's at a dealer he's probably looking to make some profit so the price might be a couple of thousand higher than it's actual worth at this time.
It sounds like the car was 'sitting' in that 'collection' for a while and not being driven since the brake calipers and fuel system needed to be replaced.
This is an indication that it might continue to need various work done on it as you begin to drive it regularly.
Do you know about the rust problems with 68+ Corvettes? Do you know the signs to look for? Do you know anyone with some 68-72 knowledge that can look the car over with you?
It would really help to have a few pictures to look at. What is your definition of "immaculate"? How recent was the paint job? What is the age and condition of the tires?
Just based on the info you've posted it sounds like perhaps a $15k car...if it's rust free.
Regards,
Alan
Alan, you mentioned that various work may need to be done as a result of the car sitting. Could you please elaborate a little?
I don't know the age of the tires but condition appears to be good. I didn't see any "checking" or cracks, tread wear seemed to be fine as well.
Don't know when the car was last painted. It does look good even up close but there are signs of over spray and the "details" aren't what you would expect from a show car but appears as a good driver.
I'm curious to see what you all recommend for me to look for with respect to rust.
I have a few more photos if anyone is interested unseeing more.
Thanks to all for your help so far!!
I certainly appreciate everyone's feedback to this point and look forward to more.
Regards - B
The interior does look good in those pictures. If the rest of it is in similar condition this may be a nice find.
It would be good to see additional photos of the exterior, engine compartment, and chassis.
These pics might help in getting an idea of the car's completeness, originality, and condition, which would give an indication of it's value.
The rust can occur on the frame. Especially vulnerable is the area right in front of the rear wheels where the 'kick-up' is that also has the pocket for mounting the front of the rear trailing arm.
Rust also can be a problem in the steel 'birdcage' that is the frame around the passenger compartment. It includes the windshield frame, cowl, hinge pillars and lock pillars. On coupes it also includes the 'halo' and center roof bar.
You can get some idea of it's condition by looking carefully through the windshield from the exterior for signs of rust or rusty stains on the small part of the windshield frame visible at that point. Also look at the point at which the a-pillar meets the cowl. The best view of the hinge pillar is when the lower kick-panels are removed. Sellers often don't want to do this since the sill plates need to come off to get the kick panels out.
I mention rust because, although not all cars have it, it's an absolute deal breaker because there's simply NO reason to get involved with a rusty Corvette. Let it be someone else's problem.
I mention work needed because of sitting…. as you know sitting unused is actually hard on a car. Anything made of rubber ages (bushings, hoses), anything holding a liquid with a seal wants to begin leaking (radiator, engine seals, transmission and rear differential seals), and older parts and assemblies that have been o.k. just sitting are now being stressed and may want to fail (engine, transmission, rear differential). The question of tires has to do with their actual age not their appearance. Tires can look extremely good but because of their age be dangerous to drive on.
So!…. some more pictures?
Regards,
Alan
Without compromising your find, can you share anything about your location and the car's location? What do you know about where the car has spent its life? Climate(s) and other environmental conditions over time matter to a car like this.
Also, know that "numbers matching" on Corvettes gets pretty deep. Smaller components such as glass, carbs, rims, starters, fan clutches, jacks, etc all are date-stamped and are looked at in judging. You may not have an interest in having your car judged when you buy it but strange things happen after you buy the car and get introduced to the depths of the hobby. Don't ask me how I know
. Even if you never get this far into the car, the next owner might want to consider it, and this affects the value in a big way.On the other hand, $15k-$18k isn't a load of money to jump in to a fun driver car. It should, though, be considered the cost of entry...
Regards - B
It was mentioned above that you replaced the carb. For some that's part of matching numbers.
Which raises an interesting question. Is there any way to do a VIN search and track some of the history of the car?
It's crazy how deep this "numbers" thing can go. Never realized that even the glass is date stamped! I'm not certain that I'll ever get into it that deep but as you said the next guy might.
I'm attaching another photo or two for your review.
A word of thanks goes to all who have helped to this point! Every post I read is a learning experience. Thank You!!
One picture certainly doesn't tell much…...
But things look o.k. in it.
A few pictures of the engine compartment from different angles, and some pictures of the front and rear suspension, would likely be a better indicator as to just what the car is and also hint at it's condition.
Regards,
Alan
