Radiator?
This other radiator will be used on an engine test stand that I am building.
The other thing is even before I bought from Tom I gave that man hell, still he was kind to me and had long phone talks...to me that is priceless customer service....
C3 radiator discussions can get confusing because there were (6) six radiators during the 15 year run.
68 BB and SB with AC or Auto 22.5" Copper/Brass
68-72 Aluminum used with base car small block engines (no AC, no auto) Uses surge tank
69-72 SB 26.5" C/B used with AC, or Auto, or LT1 & L46
69-72 BB 27.5" C/B (no filler neck, uses surge tank)
73-76 All 27.5 C/B with filler neck
77-82 26.25" C/B with filler neck (that's the one in the photos above)
Your radiator was #2 on the list and it is very important to stay with some form of aluminum radiator. It is common knowledge that changing from C/B to aluminum is an upgrade so if you already had aluminum then installing a C/B is a big downgrade.
The exact reproduction aluminum radiator, like the one in your photos is $795. This is a very unique design "stack plate" radiator. The plates form a passage instead of the conventional tubes. It also has no end tanks and this is what makes them unrepairable. You cannot re-core this radiator because it is a core.
http://www.dewitts.com/collections/c...r-no-detailing
You can also get the above radiator all detailed up with date codes, painted and stickers but that doesnt sound like your direction.
The next step is our Direct Fit version on the above unit. $525
http://www.dewitts.com/collections/c...minum-radiator
Finally, here is one we make for Zip Products $399
http://www.zip-corvette.com/catalog/...inum-radiator/
Similar to our 1139063M but without a stamped upper cover plate and square end tanks. Still works well
That looks like a nice aluminum radiator.
The inlet and outlet hoses are at a slightly different location and angle than the original Harrison.
Also, the radiator in your picture is set up for a radiator cap and overflow hose.
The original radiator in P71's car has a surge tank with the radiator cap on it.
Also, I'm not sure from the single picture just how it might be mounted in the core support since it appears it doesn't have the 2 required 'pegs' on its bottom, nor the center bracket on the top, center for mounting to the top of the core support.
These things may or may not be a concern to potential users.
Regards,
Alan
Alan,
The radiator in my Pic is for an '81, The PO would have to get the correct radiator for his year, as Tom posted above
It appears they back up their products. Warranty looks to be basically the same for both. I also haven't seen anything written bad about them.
If I have to choose between the 2 I am saving myself $200.
http://www.championradiators.com/
http://www.championcooling.com/
Is straight antifreeze a no no? I thought all antifreeze is already premixed and can be used right out of the jug you buy it in? I am just about to prep my car for storage, and will be checking/replaceing the coolant.
Sorry if this is a hijack, but I need to clarify this now.
My understanding is that using 100% anti-freeze reduces the cooling capacity of the cooling system.
Not all anti-freezes are 'pre-mixed.
From what I've read on the NCRS Board it appears using a GO-5 antifreeze is what most suggest, and also suggest a 50/50 mix.
BUT there are MANY DIFFERENT OPINIONS on what to use.
Regards,
Alan
Unless the label says 'pre-mixed' or similar, assume it's not.
They are made in China and shipped here. How much stuff made in China is in your house. How many parts on the newer vettes are made in china. How many reproduction parts you buy for your C3 are made in China. You are not going to get away from Chinese made products.
I'll keep track of all the C7 parts I replace and see where they are coming from. I replaced an amplifier last week on one, it was was made in Germany I believe
QUOTE]
sorry to say champion doesn't hold a candle to toms workmanship inside and out, and he is a call or email away and is car and vette savvy unlike the champion tech I spoke to.
you are so very correct, Tom a supporting vender of an American made product is right here to lend a hand and offer valuable tech....Champion is not.....
QUOTE]
I think I gave Tom over 200.00 for my custom made unit, I have seen Toms in person and Champions...sorry to say champion doesn't hold a candle to toms workmanship inside and out, and he is a call or email away and is car and vette savvy unlike the champion tech I spoke to.
It's funny because I have also seen both. And they both looked basically the same to me and the guy who paid for the Dewitts.
