SDS Photography 1968 Vert Build Thread
Old Nov 18, 2014 | 10:21 PM
jr73's Avatar
jr73
much better
Old Nov 19, 2014 | 05:50 AM
SB64's Avatar
SB64
Originally Posted by SDS Photography
I have seen your thread a couple times in searches - it is my next full read since I have finished doorgunner's
Oh okay, and thanks for looking. You look like things are getting done. Car looks better already with the front cleaned up. Good job!
R
Old Nov 20, 2014 | 09:45 AM
Swimtexan's Avatar
Swimtexan
Sub'd
Old Nov 24, 2014 | 03:20 PM
SDS Photography's Avatar
SDS Photography
https://www.corvetteforum.com/forums...ght-issue.html - fought this Saturday and hope to get it worked on Wednesday.
As I said before this car is incredibly slow. So, I started to look over the engine and came back to these two hoses to nowhere. I think the bigger one should go to the carb somewhere and the one from the carb should go to the empty hard line that returns to the gas tank. Am I correct?
Old Nov 25, 2014 | 01:14 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
SDS,
Your big, short hose connects to the bottom side of the air cleaner assembly. If you remove your top lid and filter, you should see a little flame arrester. It connects there. That hose looks to be bubbafied, I would consider purchasing a new one.
I believe your smaller connection, that appears plugged, usually has a small flexible rubber tubing connected to it that supplies the vacuum for the A.I.R. diverter valve.
Old Nov 25, 2014 | 01:17 PM
LeMans Pete
Note that these connections are not the reason your car is "slow." Is this motor the original 327/300 HP motor? It sure looks like bubba has made a visit (looks like a late-C3 t-stat housing?), so you really need to determine what parts you may have. Look at the engine stamp pad and start there. Which cylinder heads do you have? Carburetor?
You'd be wise to work on the ignition and induction system.
Old Nov 25, 2014 | 02:00 PM
Kid Vette's Avatar
Kid Vette
Looks like the thermostatic coil is missing for the choke. That would be why it "does not want to stay running when first cranked".
Old Nov 25, 2014 | 02:41 PM
SDS Photography
Originally Posted by LeMans Pete
SDS,
I have a hose from the other valve cover that I think connects there or to the carb - I will check.
I had a thread where we IDed my motor as a '71 GM replacement motor, a truck intake, and a replacement (not good) carb.
FOUND IT - https://www.corvetteforum.com/forums...my-engine.html
Please help me here - can this be fixed?
Old Dec 5, 2014 | 10:00 PM
SDS Photography
Ok guys, need some help. Last class is tomorrow, so tonight I got to take the car apart a bit. Behind the gauges is a mess - loose wires everywhere and a mixture of aftermarket and factory wires.
If you can label anything please do.
Pic 1 is my helper before wife gets home.
I have no idea what that that relay is
The aftermarket gauge was halfass wired into a factory plug. There are two three prong plugs - one has a red, black, and green wire and the other has blue wires in it.
Old Dec 5, 2014 | 10:05 PM
SDS Photography
This post involves things found around shifter. There are loose wires around the shifter, a cat 5 cable, and wires going to the rear of the car. If you can label anything please help.
There is a cable that should attach to the blower controls but there are already two attached.
In the last pic you can see the other detached blower cable that is up near the dash pad.
Old Dec 6, 2014 | 07:35 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
How did you get pics of my dash wiring? LOL!
parking brake warning light wiring=Tan & pink wires
Tach ground wire=Black
Ignition switch light wire=grey and black wires
Windshiel wiper switch=dark blue, black, 2 light blue wires
doorajar light=light blue, pink wires
clock light=grey wire(grounds itself to back-plate)
clock power=orange
console light=grey wire("" "" "" "")
gas gauge light=grey("" "" "" "")
gas gauge power=tan, pink wires
heater light=grey, black wires
heater switch=pink,brown,light blue,orange,yellow
heater resistor(inside the air duct box)=light blue,yellow, orange
lighter light=grey(grounds itself)
lighter power=orange wire
temperature gauge=green,black,pink
battery gauge=black, black/w/white stripe
parking brake warning switch=tan wire
passenger's courtesy light=orange, white
passenger's door switch=white wire
left kick panel vent door cable=left round **** manual lever
right kick panel vent door cable=right round **** manual lever
left/drivers heat/cool thumbwheel cable at air-box=I forgot where it leads to...use your imagination
right/passenger's heat/cool thumbwheel cable at air-box=I forgot
Have fun!
Old Dec 6, 2014 | 08:43 AM
SB64's Avatar
SB64
clock power=orange
Have fun!
Hey DG that's a pretty impressive list you got going
Old Dec 6, 2014 | 10:03 AM
  #33
PRNDL's Avatar
PRNDL
Originally Posted by Brandons72vette
Whats up with the tape on the upper radiation hose?
Is that tape or aluminum foil? Looks like something I would do if the hose is making contact with the fan shroud. The tape is there to protect the hose. Of course, you could install the hose so that it doesn't touch the fan shroud but Bubba (ie, me) prefers to manufacture a hose protector sheath.
Old Dec 6, 2014 | 10:35 AM
  #34
SDS Photography
Have fun!
Did you do this from memory? That is nuts!
Much thanks
Old Dec 6, 2014 | 10:46 AM
  #35
doorgunner's Avatar
doorgunner
Much thanks
Nope......wiring diagram courtesy of forum member PAPPAWANA!
I did spend 2 hours re-tracing all the little black lines with the correct color marking pens though (I got headaches looking at the black & white diagram while standing on my head chasing loose/cut/spliced/taped-up/shredded/fried wires).
Nuts! Yes.....according to the V.A. Shrinks (I am well-documented/my car---not so much)
Old Dec 6, 2014 | 10:53 AM
  #36
SDS Photography
That must have been a long process.
Any idea on the wires that terminate around the shifter? I think they are yellow and a lot of black wires.
Or, the green yellow and red coming from the back towards the shifter? Lights at bottom of center console?
Old Dec 17, 2014 | 09:36 AM
  #37
SDS Photography
Ok, got the car up on a lift. Good and bad things - the underside looks clean and original but like a survivor it has bad bushing and mounts. There are also a couple of leaks (oil filter and rear of transmission) - I plan just to monitor levels until motor swap.
Couple of things that I am now considering/planning -
Grand am power steering swap
Still looking for seats
Getting wiring under control and interior put back together.
Old Dec 17, 2014 | 09:39 AM
  #38
SB64's Avatar
SB64
I mean all and all things don't look to bad from what you are showing. yup bushings on front stabilizer are shot, anyway carry on.
R
Old Jan 7, 2015 | 11:19 AM
  #39
SDS Photography
Ok, after sending back switch to amazon I bought and installed the correct one - I now have blinkers, brake lights, and turn signals! I also bought and Edelbrock 1406 carb and intake to try to get back some HP from my current top end stuff. Also, started acquiring parts for an electric fan install.
