stainless brake line clamps
Just like the title says. Does anyone here know were I can pick up some stainless steel brake line clamps that I can use in place of the stock ones? I am going to use stainless lines to replace the ones in the engine bay and I would rather not use the regular stamped steel replacement line clamps unless I can help it.
I would also like to know who makes the best quality emissions label that goes on the firewall above and behind the brake booster for my 77 ? Thanks
Received 2,878 Likes
Hi p,
I'll try the label; there are only a couple of producers so what the vendors are selling are pretty much the same.
You really need to get a couple to compare to you original if you want it to be as close to the original as possible.
You can also try Jim Osborn Reproductions. He deals in labels/decals/literature.
Regards,
Alan
Regards,
Alan
