why not a 68?
The reason for the change was simple, not enough fiberglass between the headlight opening and the hood opening. Cracks were starting to appear in basically new cars.
Personally I don't really like to look of the mud flaps, but they sure are functional.
Yes, indeed, Wally. If I was on the street and your yellow beast pulled up behind me - I would pull over and let you on by. Respect, brother. Love your car.
Imagine a line that runs from the front corner of the hood to the extreme end of the chrome bumper...under that top panel (front surround) is a vertical inner fender. On the '69 and later cars, a small L-shaped tab was attached to the inner fender and helped support that panel. If you see the edges of the hood a bit high this is a possible culprit...but it can also be for other reasons or on a mis-aligned '69 and on, as well. Some '68s do not need them, some have had them added and some still sport the mis-alignment. So it's not exactly a sagging nose, it was/is an issue with alignment of that panel to the hood. I have a '68 and designed my own fix. If you notice the red '68 in this thread, the alignment is perfect...so obviously its either not needed on this car or has been addressed. It's a simple thing to take care of.
It is just the way it came, never changed. And one day in July, 1980, I tried extremely hard to both change that and preserve that. I was headed into Turn 1 at Mid America Raceway, thinking about the braking point that Walt Kopecky had just told me he and others used when racing, and as I squeezed on the pedal hard, a thought crossed my mind. They were on slicks, not street tires.
As I spun the car at something like 120 mph, I kept thinking, keep the nose off the wall, keep the nose off the wall. I can put the rear back together, but I will never get the nose straight.
After the dust cleared, I had spun 540 degrees. Completely around once and another half so I was pointing where I came from, and still in the middle of the track, far from the wall. Still running, I let the clutch out, spun it back the way I was going, and took off.
Pete
I will say this though, on my 68, I bumped the ignition key and accidently had it in forward gear and of course it lurched forward a bit. So, I thought, oh yeah...., no start in gear protection with the little cable going from the trans to the steering column. Maybe my late March 68 was supposed to have that, but I think 68 did not have that since the ignition key is in the dash. Knowing a couple of owners of the older ones that suffered front end damage when the car lurched into a work bench, reminded me this is something to be aware of.
Also, since I now have a 68, I also find I push the lock cylinder on all C3's to open the doors!!!
then he scrapped it and went with.........
Annnnnd since I'm a chrome/gloss-black guy (Harley Davidson inspired).....I already installed the chrome mufflers/may as well throw on the emblems.....
BATS! You're stuck in the 60s!
On the other hand.....if I had to be stuck......that would be the time....right before I went to "beautiful. fascinating Southeast Asia to see new faces and make new friends"....
She, and that car will be forever burned into my memory...
Run away, run away
Just saying.
