Rear Crossmember Bolt
Old Jan 8, 2015 | 07:42 AM
cgarcer's Avatar
cgarcer
Default Rear Crossmember Bolt
Anybody ever broken one of the bolts that holds the rear crossmember to the frame? I did. I was unsuccessful in trying to extract the broken part. I am going to see if I can drill it out and retap it. If that doesn't work, I'm not sure what I will do next.
Old Jan 8, 2015 | 01:27 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Is there any of the old bolt you can get to? Normally we would just weld a nut on the broken portion left. The new head combined with the heat will normally break it loose.
Old Jan 8, 2015 | 06:24 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
And if you do drill it out.....slow the drill motor rpm by about 80% to prevent ruining the drill(bit) and prevent work-hardening the broken bolt.
Old Jan 8, 2015 | 07:40 PM
DUB's Avatar
DUB
DUB
To Rear Crossmember Bolt
