I have been struggling with the heater core on what I thought was a factory a/c 1968 roadster. Everything in the engine compartment looked factory however I found several things that lead me to believe the a/c was added later. The first was that the hole for the wiring harness was too small to get the connectors through. No biggie...I opened it up. My latest issue has been the core. When I removed the a/c box to install the correct switch on top I thought I would replace the heater core while I was in there. Several of the screws on top and on the right attaching the box to the firewall were unusually long. Upon reinstall I noticed the right side of the box sits about 3/4" off the inside of the firewall. The picture is the inside view of the opening in the firewall. The core pipe hit the casing on the other side of the firewall. See the attached picture. Does this look correct? I don't know what it is supposed to look like. Thanks
Thanks for the help. I was not getting much response on this one. I think the culprit is the replacement heater core. The bends in the pipe seem to be holding it off the fire wall. I ordered one from Zip. Hopefully it will work. The last two bought locally did not. Thanks again.
I'm going to say that the hole in your firewall, looks to be pretty crudely cut to me. I know that 68's were a learning experience for GM, and the build quality wasn't all that good, but that doesn't look like the factory hole to me.
I have a clip from a 75 AC car at the shop, and the hole's cut much cleaner than the one in your car. I'll get a couple pictures later, and post them.
Even if the hole is cut right, it's no guarantee that the heater core you have coming will fit right. The tubes on the AC cores are often an issue. The tubes almost always need a little "adjustment", to get them to fit. It doesn't seem to make much difference if it's an original Delco cores, an aftermarket US made one, or a replacement from Mexico or Taiwan, the tubes never seem to be positioned exactly right.
...It looks like the hole was made with a sawzall...
Might have been a sabre saw. At the front of the AIM there is page showing how the stock heater core firewall hole had to be opened larger for the optional factory air. If memory serves, the page says the cut made on the assembly line was supposed to have been "neat." Wishful thinking.
I appreciate that. The tubes on the last one were holding the whole box off the wall about 3/4". I was certain I would break them if I tried to move them that much. I am hoping for a better fit on the next one. It not the original one is going back in!
It's a mystery but I still think it's an original unit installed in a non air car. Just guessing.
The pictures below are of a 75 factory air car. The first picture is looking at the firewall, from inside the car, and the second picture is from the engine side of the firewall.
Compare the shape of the recess on the right bottom side of the opening in my first picture, to that same recess in your firewall. The factory cut has a smooth flat bottom, while the recess in your firewall is rough and curved. Actually, you can see that the edges of the opening in your firewall, are very rough all the way around, while the edges of the opening in the 75 firewall, are crisp and smooth.
I'd say that someone has converted your car to factory air. This is not a bad thing, though you may want to use my pictures to clean up the opening in your firewall a little, before you put it all back together.
Out of curiosity, what does the air vent above your center gauge cluster look like? 68's have a unique, one piece vent. 69 and later AC cars used a two piece center vent.
The vent is the later model two piece. I searched for a correct one but just like the 4-speed console plate they are not cheap. The controller is also incorrect but it should work.
