A couple years ago I had to have a new windshield installed in my 82 and when the did the upper windshield trim never fit right. There was a gap and has bugged me ever since so tomorrow I'm having a glass company come out to remove it so I can replace the trim clips and just to inspect. Now I have looked in the AIM and they show a foam insert or something?? So my question is what is the correct procedure? The lady on the phone told me they can either use butyl caulk or the regular adhesive which is what is on there now. What do you use to get the windshield to sit high enough so the trim sits flush with the glass?
Hi alc,
The original installation of the glass held it away from the windshield frame a certain distance. This insured there would enough adjustment in the trim (there's only a little bit) to have the trim be snug against the glass. The original installation made use of a firm foam 'damming strip' which acted as a spacer around the entire perimeter of the glass.
The gap should allow only a single piece of paper to be slid between the glass and trim.
I recommend dry fitting the glass and trim first to establish what the distance between the glass and frame should be.
Regular glass installers don't want the hassle so you see cars around with horrible gaps.
Regards,
Alan
Here is a thread where some of us talked alot about this issue and how to do the install. It has a few different ways of doing it.
Thanks Alan and Tim. I will pass this info on to the glass installer and hopefully he'll understand.
If he watches the Video on the the
thread he will get a good understanding how to do it but make sure he understands the end results to to have the trim laying on the glass with no gap. If you are using new glass he will need to use 3/8 damming strip to get the gap you are looking for if you are going to use the damming strip method. In the Thread you will find a process that willcox uses not using damming strips.
Now should the trim be flush with the chrome t-top trim? See how it's below it, I don't know if that's correct or not? And you can see the gap underneath the trim as well.
Good Luck
I will be using the existing glass and doubt the installer will watch the video. I plan on after the glass is removed is to remove all the old adhesive from the frame work just to start over cleanly.
Hi alc,
That's not a typical fit.
It's not possible to determine what the problem is from one picture.
My bet would be that the long thin piece of ss trim isn't installed behind the clips as it should be, but rather is in front of the clips which has pushed it forward and down.
It's also possible that the large piece of ss trim isn't clipped down over the edge of the windshield header properly and is thus to high and won't let the small piece seat properly.
It also could be…… anyones guess from one picture.
You won't know for sure until you begin to take the trim off.
Your installer likely won't be happy because he's used to installing present day glass with often no trim for him to have to worry about.
Regards,
Alan
Well the glass is out and the car was missing two clips and had a couple broken. The ss trim was clipped over the edge so that's good. I asked the installer several questions and he had a dumbfound look on his face. I'm tempted to install the glass myself... Now a new problem has arisen, I took liberty to do a through clean up job scraping cutting the old adhesive and butyl away but in doing so I broke off the edge of the dash pad. So now do I replace the pad since the windshield is out (looks easier) or glue the piece back on if that's even possible????
Ouch on the dash pad.. The only reason I have not finished putting my Windshield in is I have not purchase the dash pad yet. After reading threads on installing the pad it seems a good idea to do this while windshield is out.
If you need a few trim clips I have a bunch of extras... Let me know..
Originally i was going to have a installer do mine glass Insulation but could not find anyone that would assure me that the trim would lay on the glass.
Thank you on the offering but I bought a NOS set of clips and screws and waiting on the arrival.
Maybe someone with some experience on repairing the pad will chime in.. My interior was trashed and not salvageable so I have had to replace the complete interior.
