kick panel speakers?
Old Feb 8, 2015 | 01:54 PM
7T1vette's Avatar
7T1vette
The amp needs to be in open air...where it can dissipate heat. Not enough room behind the seats, unless you are short enough to have the seats forward. Mounted to the rear compartment panel is a good choice.
Old Feb 9, 2015 | 12:02 AM
qwank's Avatar
qwank
I have a huge amp behind my seat and it's just fine. The car gets a ton of air flow into the cabin, especially with the tops off.
I also have the 5'' deep box with the ten and two 6x9s. They do sell a version for a 12'' sub. I'm going to eventually put kick panel speakers in, get rid of the 6x9s, flip the box around so the sub faces the back and mount my amps to the back of the box facing forward.
Old Feb 9, 2015 | 01:52 AM
jtl1567's Avatar
jtl1567
that looks sick! whats the benifit of facing the amp to the rear? also this may be a dumb question, but is the stereo slot a 1din?
Old Feb 16, 2015 | 02:09 AM
jtl1567's Avatar
jtl1567
so i want to put in a 1200w sub 300 rms, two 6x9 at 460 watts 230 watts each, two 6.5 at 350 watts each 50rms each, what size amp do i need?
Old Feb 16, 2015 | 03:19 AM
13611's Avatar
13611
It's really up to you... and your wallet size. For quality sound you're going to want to run two amps. A mono amp for the sub... I'd aim for 500+ watts. And a four channel amp for the other speakers... I'd go with a good quality, name brand amp that puts out at least 60 continuous watts per channel. If you're going with an off brand, go with 100 watts per channel to make up the difference. You'll also have better luck with these types of questions running a thread in the general--audio section of this forum.
Old Feb 16, 2015 | 07:46 AM
rastafford3164's Avatar
rastafford3164
Hey qwank, can I see a couple more pics of how you mounted the amp behind the seat?
