Quick question for the group. I have a 76 automatic l48 with 26K miles on it. I had I very minor trans leak from the trans gasket. Happened randomly. When I checked the bolts on the trans pan they were torqued are less than 8 ft lbs. I guess this is from the years of compression.
Should I go back and tighten to 11 / 12 ft lbs or just leave leaking dogs lie? Seems if I can turn them by hand they should be tighter.
You can torque them to 12 no problem, but the oil found a path, so it will leak again eventually. I hate oil leaks.
Thanks Mick.
I am just fiddling until the spring comes. I will go to 8 then 10 then 12. I really feel that leak is from the pan being so loose. But I have a new gasket and filter anyway...
Torque them up again. If that doesn't work then you can change the gasket if you want to stop the leak.
If it's not leaking on mine it might be out of oil.
Cork or cork/rubber gaskets will continue to compress with time & heat cycles. Usually, when that pan gets resealed, you want to go back and re-torque those bolts after a few days use.
Try to re-torque them (for now). If you find that one or more don't want to snug up, you'd better leave them be. When you do change the fluid/filter, you'll also need a Heli-coil kit to repair the holes with 'loose' threads.
Went and tightened all back to 12 ft/lbs but did so in 2 lb increments. They were all around 6lbs to start with and they all took the final 12 nice and evenly so no heli-coils.
If it drip now its replacement time but have to believe that the pan bolts being torqed to half their spec had something to do with a drip. Actually is shows just how little force is needed to hold a gasket and pan in place.
Actually, at 6 ft-lbs torque, a 5/16-18 bolt will have around 1000 pounds of clamping force. With 15 (or so) bolts on a tranny pan, that's a lot of clamping load. 12 ft-lbs torque would have about 1 ton of clamping load per bolt.
Most likely, the pan gasket is compressed, oil soaked, and basically used up. If it stays dry for a while, great. If it doesn't...no big surprise.
Re-do it when you get the chance. You probably should consider re-sealing all of the external seals and O-rings when you have the opportunity. That's not a big challenge, mechanically; but it takes a bit of research and ordering to get all the needed items to do that job. I never understood why some of the rebuild kit outfits didn't make up an "automatic trans reseal kit" with all the needed stuff for various trans models.
You may also want to redo the shift shaft seal. If so, just remove the arm from the shaft, clean everything really well on the outside, then drive the existing seal down to the bottom of its bore and install the new seal on top of it (to proper depth). There is room to do that, if it hasn't already got 2 seals in there; and you actually end up with redundant seals! (Plus you don't have to screw around trying to remove that 1st seal.)
If you don't have a 'driver' for that seal, select a properly sized deep-well socket that has an O.D. just smaller than the seal's O.D., and an inner diameter that will clear the shaft. Be careful not to scratch/damage the journal on the shaft and the bore the seal fits in. Also, take care not to cut the seal lip on the sharp edges of the flats machined on the shaft.
