This all started with the purchase of a 1981 Corvette back in about 2004. The car is numbers matching 4 speed that took a right front diagonal ditch hit. This resulted in some fibreglass damage and a slight torsional twist to the frame.
STARTED STRIPPING!! SEEMS IT COMES APART FASTER THAN IT GOES BACK TOGETHER , DESPITE THE RUST, BELIEVE ME!!
We decided to do a complete frame off on this ex-Michigan car in order to get everything straight.
THE BUILD SHEET
Ironic that the build date of the gearbox shown was my 19th birthday! Just about the time I was dreaming of owning a new corvette just like this!!
Hi J,
You're right about them coming apart much easier and faster than they go back together….. and into a surprising number of pieces and fasteners TOO!
Good Luck as you get going again!
Regards,
Alan
Having stripped the body and lifted it off, we then removed the drivetrain, exhaust and suspension. Left with the bare frame, it was off to a friends yard for sandblasting! Then a coat of etching primer with rust inhibitor.
The frame was then painted with two coats of semi gloss rust paint.
Pretty sure we will have to remove the clip to address several issues including;
delamination of inner support panels on the rear edge of the fenders, probably due to impact shock
Surface rust on the upper birdcage frame extending down behind the fender tops. I believe removal of the clip is the only way to thoroughly clean and prep this area. Any members face this same issue?
Ok fast forward to present day!!! We managed to get the frame rolling of sorts. Still have to tighten and adjust components, but we needed to start at least dry fitting some stuff. Plan is to get the suspension finished and drop the engine and gearbox in in a few weeks. From there we will work on the fuel system (new tank on order), exhaust
(stock setup for now) until we get it fired up and running good. Want to keep everything reasonably stock with exception of heads(maybe), new cam and headers(duals or side pipes) to try and bump the horses to a reasonable level.
Gonna hit the diff with the pressure washer to brighten it up, remove the dirt and grease from the rough cast. Will post pics on how it works.
As stated earlier, we bought the street slalom kit which included the composite leaf altho I'm a bit concerned about the clearance between the spring and rim. I'm trying to determine if the weight of the body/drivetrain and settlement of the suspension will widen this gap from what seems very close right now. Any members care to share their experiences? I realize there are no adjustments made here yet , so this may be concern for nothing to this point!
My hair color WAS about the same as yours when I started on my car
Glad to see you got a helper, I've had to do everything my self, it's easy to lose interest that way. You've got a good start, keep it going, it's inspiring for me.
So was mine! LOL but then I have two buddies who are as bald as cueballs!! It may be grey but I still have mine!! Will keep it going!!
Hi Jomor, looks like you are moving right along. Your 1st question about rusted birdcage areas. You may also want to remove the stainless trim on top of the windshield if you have not done that. Remember to not torque all the suspension until you have the weight of the body back on . This will let everything settle properly. Looks good. Carry on!
r
Hi dprinter1, you are so right about having a helper. I have lost all interest in continuing my restore.
r
