Trans conversion
Old Mar 7, 2015 | 03:04 AM
eurekax's Avatar
eurekax
Default Trans conversion
I have a 72 stock small block with 3 speed auto trans,as I do lots of freeway driving I would like to install a 700R4 box for better fuel economy.will a 700R4 trans just bolt in with out any problems,apart from tail shaft length,any info would be helpful Thanks Alan
Old Mar 7, 2015 | 03:22 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Click on these links:
https://www.corvetteforum.com/forums...ght=700r4+swap
https://www.corvetteforum.com/forums...ddly-bits.html
It might be cheaper/easier to change the ring and pinion gears in the differential to lower highway engine rpm.
Old Mar 7, 2015 | 04:58 PM
rkingce's Avatar
rkingce
You also have to relocate the trans support brace. And no, changing gears isn't a better option. You lose the low end power. I have great low end and @ 1700 rpm I'm doing 70 mph and 16 mpg With 3.08 gears
Old Mar 7, 2015 | 05:43 PM
Kris Tunetso's Avatar
Kris Tunetso
The 700r4 is not a bolt-in swap: you have to relocate the transmission crossmember further rearward. If you want a bolt in automatic with overdrive, look into a 2004R. Plenty of info about it here in General and over in Tech/Performance. It's the most common swap since it's a bolt-in replacement.
Old Mar 7, 2015 | 06:08 PM
SIXFOOTER's Avatar
SIXFOOTER
The 200 R4 is a better bolt in swap.
Slightly better overall gear ratio, same drive shaft length.
You will need a new trans mount and a Shifter kit so that the shifter will work.
Well worth the effort
Old Mar 7, 2015 | 06:23 PM
Kris Tunetso
I forgot about the driveshaft length. You're right: if he goes with a 700R4 he'll have to shorten the driveshaft in addition to relocating the crossmember. Thanks for bringing that up.
About the shifter kit, I just want to have this said for full disclosure, that way eurekax knows exactly what he's getting into. If you only ever put the car in D, then you don't need to get the shifter kit. However, you wont be able to manually put the new transmission into 1st gear as the existing shifter detent is only for 3 gears, not 4. If you want to have full access to all the gears in your new transmission, you'll need the kit. As a plus, they sell a little gear indicator showing you have 4 gears instead of the stock 3. Makes it look factory. Shiftworks sells them, as does Bowtie Overdrives, though I think BTO just sells the Shiftworks kit.
Old Mar 7, 2015 | 07:08 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Might want to try these guys: http://shiftsst.com/ . They make complete kits to fit the car. The are the ones who took over Kiesler after the bankruptcy. From what I understand they are great to work with.
Old Mar 7, 2015 | 07:29 PM
Kris Tunetso
Full disclosure, the only automatic they offer appears to be a 4L60E, which is an electronically controlled 700R4. If you're not wanting a computer-controlled trans, or if you decide you'd rather have the 2004R, SST does not appear to have anything for you.
Old Mar 8, 2015 | 09:03 AM
SIXFOOTER's Avatar
SIXFOOTER
Thats true, I went ahead with the shifter kit in mine because I wanted full control of the tranny, which has the shifter reprogramming kit and all the other bells and whistles in it.
Old Mar 8, 2015 | 11:17 AM
Blue79's Avatar
Blue79
Stock engine, freeway driving, bolt-in; it all points to a 2004r. Anything other than this, you can always hop it up. BTW, mine does just fine with one.
Old Mar 8, 2015 | 11:29 AM
briankeery's Avatar
briankeery
Like the boys are saying, the 200 will be a much easier/happier way to go. Try contacting Bowtie Overdrives, as I haven't seen them mentioned yet. Pretty much a one stop shop for this conversion. Remember to document your conversion here with lots of pics.......we all love lots of pics.
Old Mar 8, 2015 | 01:51 PM
7T1vette's Avatar
7T1vette
The THM-200-4R is a better trans to install in your particular vehicle. The stock crossmount bar and mount will still work with that trans. There are still quite a few mods that need to be made to get it installed and working properly. If you are going to do the work, you need to research this swap THOROUGHLY before initiating this project.
The 200-4R [or 700-R4] need to be upgraded for strength, they need to have the correct output housing configuration, need pan mounted brackets modified, need different fill tube mounting, and need the T.V. cable installed and adjusted properly. If you want lockup operation, you will need a lockup converter (selected to match your engine's needs) and it would be best to have a lockup controller to manage lockup operation properly.
It's a good swap...when you get it all done.
Old Mar 9, 2015 | 05:22 AM
riverracer au's Avatar
riverracer au
one link Doorgunner posted, was to my 700r4 swap in my '72 that i'm in the middle of,
i did a lot of research on here and the net, but still have/had a lot of questions.
i've tried to cover all the "fiddly suff" that no one else covers...
i didn't shift my x-member, just used a different case mount that puts it within 3/4" of a T400.
BTO sell a new x-member with the mount in the correct position, one less headache.
yes the driveshaft needs to be shortened, but no biggie in the scheme of things.
i bought the shiftworks "shifter kit" which includes a new detent plate, but i haven't installed it yet.
reading here, you can just notch your existing plate to enable 1st gear selection, but...
i have hooked my cable up with SW bracket that mounts onto the pan and i can select ALL gears, even 1st.
as i'm downunder, i went with the 700r4 (t700 as we call them) as they came in early 90's GM Holden cars down here.
otherwise i would be up for $$$ in shipping to get a 200-4r here.
ask as many question as you need.
ps: you've got same name as well, Alan...
Old Mar 9, 2015 | 09:11 AM
jnb5101's Avatar
jnb5101
I'll throw some cold water on this. If the ONLY reason to swap the trans is to improve fuel economy, consider how many miles would need to be driven to recoup the cost of the swap. JMO.
Old Mar 9, 2015 | 11:37 AM
Kris Tunetso
Good point. However, for some recouping the cost isn't a consideration. The conversion makes the car more pleasant to drive with lower RPMs at highway cruising speeds, and is easier on the wallet as you (ideally) don't have to fill up as often. It's worth the expense, even if it takes a long time to 'pay off.' This, I presume, is the mindset eurekax is approaching with.
Old Mar 9, 2015 | 12:42 PM
doorgunner's Avatar
doorgunner
That reasoning is true for most things we do to our projects.....usually the only way anything is cost-effective is....if we do everything ourselves.....rebuild suspensions/rebuild engines/rebuild transmissions/paint/etc.
Then there are members like riverracer au........it costs him nearly as much to have a transmission shipped to Australia as it does for the transmission itself! I was going to ship him a $50 trans-part....the shipping cost was $70! He has to choose his modifications carefully.
Old Mar 14, 2015 | 11:35 PM
GTENIT's Avatar
GTENIT
Default Gtenit
The main thing no one has mentioned is you will need an output shaft out of ath350 out of corvette only, at least to use the 700r4
To Trans conversion
