I could be wrong. More knowledgeable members than I should be on later this evening (once we're all off work) and can give a more definitive answer. Stick around.
The '68 passenger dash did not have the 'map pocket' arrangement. But, you could buy a used (or new) right dash and install it in a '68 with no problem. Corvette swap meets (like Corvette Expo around Knoxville, TN in Spring and Fall) are good opportunities to find them at reasonable prices.
Well i am looking at 2 corvettes right now. one is a 68 convertible with soft and hard top, blue with black interior, 4 speed, has a 350 crate motor in it now but the original 327 comes with it. Asking $22500, I hope to get him closer to $19 - $20K. The other is a 71 LT1 with M22 rock crusher 4 speed, blue on blue, asking $29500 and try to get him down to $25 - 27K but it is still a bit steep for my budget.
This will be my first corvette and have dreamed of owning a 68 - 72 vette since i was a kid (i'm 56 now). I am in the process of selling my '49 Hotrod chevy truck my dad and built and will be using that cash to buy the corvette. I test drove a 71 350 automatic the other day and was the first time i got to drive one let alone ride in one.
Unless the '68 is nearly perfect and mechanicals have all been redone, it is way overpriced, as it does not have the original engine.
If the crate install was done well and it is EFI, that might raise its value up to $20K, but that's about the limit for a '68 coupe without its original engine.
Not having the original engine would not prevent me from purchasing that car, if that's what I wanted. But, a 'real' LT-1, in good condition, for $25K would be the better choice.
A little known fact. If you have the normal 68 seats, without headrests, which were an option, the passenger seat will fold all of the way down and not hit the dash. Lou.
