can't shift into gear.
Old Mar 10, 2015 | 12:28 PM
Dale Morris's Avatar
Dale Morris
1st Gear
Default can't shift into gear.
Been in and out of hospital for past year so couldn't start car until two weeks ago.Worked beautifully last year before I was sick. Area where I live is humid on Gulf Coast of Texas.Car always garaged. Will start. Can't get into any gear. Is shift linkage frozen due to rust? Is pressure plate not releaseing ? or something other?? HELP !!!
other clutch issue.
Old Mar 10, 2015 | 01:31 PM
JimLentz's Avatar
JimLentz
Can you shift it into gear when it isn't running?
Old Mar 10, 2015 | 05:38 PM
Vette Fetish's Avatar
Vette Fetish
Clutch disk may be froze to the fly wheel.
Old Mar 11, 2015 | 07:11 PM
lowes-yellow77's Avatar
lowes-yellow77
Default 4 speed?
Mine is a hurst shifter but
Something similar happened to me but not after sitting after a test drive it was like the shifter was stuck. I rolled it a little and played with shifter until it shifted smoothly that was over 2 years ago and the issue has yet to show itself nor does anyone know what it coulda been
Old Mar 12, 2015 | 10:08 AM
bj1k's Avatar
bj1k
Hold the clutch down to the floor and see if you can push the car. If the car rolls , the clutch disc is not stuck . If it is not stuck tight this will probably break it loose. Might just be that the trans needs jogged a little to engage the teeth.
Old Mar 12, 2015 | 10:24 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I hope you are doing better and can enjoy the car once it starts shifting again.
As a last resort......
loose/worn/out-of-adjustment shifter linkage will cause the transmission to "get caught between gears".....
only by re-adjusting or repairing the linkage will it work correctly.
Old Mar 12, 2015 | 04:47 PM
bj1k's Avatar
bj1k
That's true but he said everything worked fine before he went into the hospital. Now if someone was using the car during that time ?
Old Mar 12, 2015 | 10:06 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
That's happened a couple of time on my 79 after storage over the winter.
Clutch plate is stuck to the flywheel.
Put in in neutral and push it away from any wall or other things of value.
I put mine in reverse and with the clutch pedal depressed turn the key to start. It will jump backwards but has always freed up after one or two tries.
Be careful!
Old Mar 12, 2015 | 10:11 PM
doorgunner's Avatar
doorgunner
Linkage can be "squirrely" at times.....mine locked up at a traffic light once.....NOTHING made it pop back into place....had to have it towed and the linkage rebuilt....it was fine after that.
Also....a manual trans. that is low on oil will not shift sometimes!
But I'm not saying that's the problem....just a possibility.
To can't shift into gear.
