Transmission Leak
Old Mar 13, 2015 | 03:06 PM
mbendykowski's Avatar
mbendykowski
2nd Gear
Default Transmission Leak
My 1975 TH 350 transmission developed a fluid leak for the second time. Is this common?
Old Mar 13, 2015 | 08:53 PM
74modified's Avatar
74modified
You might want to try giving a little more detail. I can think of a dozen different places it could leak, and a couple of reasons for each place to leak.
Old Mar 15, 2015 | 02:32 PM
7T1vette's Avatar
7T1vette
If you are referring to the front (input) seal, then "Yes", it's very common.
Some folks try to just replace the seal and nothing else. Unfortunately, if the seal is worn, the bushing is likely worn out too. Just replacing the input seal won't work for very long.
If you have a leak somewhere else on the unit, please give a better description. There are about a dozen 'common' areas of leakage on any GM auto transmission.
To Transmission Leak
