shimming alternator forward
Old Mar 20, 2015 | 08:21 PM
2001convertable's Avatar
2001convertable
Default shimming alternator forward
Hi, is there a way to move my alternator forward via shims or any other way on my 71 small block? I noticed that my alternator belt is not in line with the pulley after doing the radiator. It may have been like this before but I never noticed. thanks
Old Mar 20, 2015 | 10:00 PM
gjohnson's Avatar
gjohnson
Washers?
Old Mar 20, 2015 | 10:17 PM
C3 Stroker's Avatar
C3 Stroker
Washers work. Look closely in this pic, and you can see my washer spacer between the alt. bracket and the head near the valve cover, close to the intake...
Old Mar 21, 2015 | 06:13 AM
SB64's Avatar
SB64
I have been told in my restore job that GM alignments were sometimes off a little so you may be right with it being off when you started. Washers like suggested usually fix the problem.
r
Old Mar 21, 2015 | 09:56 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Ohhhhhh.........he has the "long"-short water pump!
Old Mar 21, 2015 | 10:13 AM
Alan 71's Avatar
Alan 71
Hi 2,
I'd think you'll need to be careful about shimming the bottom bracket too which might require a longer bolt depending on how far you move it.
Regards,
Alan
Old Mar 21, 2015 | 10:46 AM
Mike21175's Avatar
Mike21175
Back in the late '70's when I had my '77, i had the same issue. I had belt squeak from poorly aligned alternator belt. This was factory. The solution was washers. Only used them on the upper areas, and then installed a new belt. No more squeal!
Mike
Old Mar 22, 2015 | 08:16 AM
2001convertable
I used a few washers and worked good but It was not off as much as I thought. thanks to everyone
To shimming alternator forward
