tyre size
Old Mar 21, 2015 | 10:48 PM
grumpyonetwo's Avatar
grumpyonetwo
Default tyre size
hello all,greeting from Australia, can anyone tell me
what is the biggest tyre size i can put on stock rims for a 79 corvette?
at the moment it has front 225/70-15,rear 215/75-15. I have just taken possession of this car(imported from US) and like everything if you dont see it first, there can be a lot wrong with car, like odd tyres on car, cracked sidewalls and a lot of small gear that is not on/in the car. So i have a lot of gear to buy and get shipped to Aus, any advise on where to purchase gear for this model at reasonable prices will be appreciated.
Old Mar 22, 2015 | 09:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Any reason why the wider shorter tires on the front? Most people put the wider pattern on the rear.
Old Mar 22, 2015 | 12:33 PM
7T1vette's Avatar
7T1vette
Unless you are going to race the car, just buy a good set of 255R60-15's for all the wheels. That way you can rotate the tires and get maximum wear out of the whole set.
Old Mar 22, 2015 | 02:37 PM
grumpyonetwo
thats what normally happen, but this is/was the tyre setup that was on the car when it arrived from the US
Old Mar 22, 2015 | 10:34 PM
bradleyb66's Avatar
bradleyb66
225/70R15 was probably the size it came from the factory with. 255/60R15 should fit ok (some people report some minor rubbing issues, but this tire size was an option in 79 also). I put some 275/60R15 on my 79 temporarily while we were getting it ready for paint (just needed something road-worthy for short trips, and had these in the shop), but the inner fender lip rubbed on the tire when going over bumps, so I would not advise going that big. (all of the above sizes fit fine on the 15"x8" rims)
To tyre size
