Frame on restoration
http://s40.photobucket.com/user/biac...RVETTE%20FRAME
Next phase is to use a wire wheel to clean the rest of the dirt and rust off at a section at a time, clean it with some type of rust dissolver, prime and paint GM Chassis black. Doing some research now to find the best product for what I want to do.
From what I have researched so far, the best thing I can do for the inside of the frame is to paint it with Eastman's rust encapsulator.
Whatever I get done between now and mid May will be it until next winter. Car comes down from the lift and onto the road as soon as it gets nice out!
Very easy one weekend job to remove the control arms and springs. Mask the area off and paint the frame. Then clean up the control arms. I had mine hot tanked then blasted. Replaced the bushings too and painted them with VHT Epoxy paint.
Frame was painted with VHT roll bar and chassis paint satin.
I also have the motor out for more room.
I understand why you want to get the tires on the ground soon! I bought a basketcase/spent 6 months going through the suspension and drivetrain to make it safe to drive.
Your car's frame looks in good shape considering it's a '76.....and it's a good idea to take one section at a time.
Take plenty of pics before disassembling components so they can be reinstalled the same way--PICS OF THE CONTROL ARM SHIMS for example to make sure the alignment stays correct.
What the other member said about completely removing/cleaning/painting the front suspension can be done in a weekend....and that area of the frame will be much easier to refinish.
Same thing with the differential suspension.....a weekend will have it looking like new.
Drop the gas tank---clean it---refinish the entire area of the frame while the gas tank is out of the car.
You get the idea!
As far as getting something like that done in a weekend? Not me! First I look at the job for an hour trying to get the nerve to start taking it apart. Once I get started I'm OK but damn slow. Then I spend an hour looking for the damn screw, nut washer etc that I just dropped and can't find! Then I spend 10 minutes looking for the tool I just put down and can no longer find. But eventually I get it done.
Did anyone notice the paint markings on the footwells? Anyone know what "894" might mean? I can't find the date code at the moment but the car was built October 10 1977.
I'm thinking the number you mention is on the passenger's side toe board in the engine compartment.
Earlier a 'job number' was written there in crayon to identify the car on the production line. The number ran up to 500 and then started over.
I've not heard of them going higher….. any chance it's a 3 and not an 8?
The job # was also written in pencil on the tank sheet.
Regards,
Alan
Here's an example. 186
If you knock only the loose rust off, you could use POR-15 or use a 'rust converter' product to make the rust inert, then paint it with Rustoleum or some other less costly paint.
This is on my list as well...
What is your opinion of the Eastwood products, and how much did you use? I received one of their kits containing 3 cans of the internal frame coating and 3 cans of their rust encapsulating paint. In your opinion will this be enough to do the entire frame?
Thanks for your input, and nice job!
Jeff
44-0894 (schedule and job number)
10-10 (October 10th)
Jeff
I painted the frame from just behind the front control arms to the front side of the rear wheels. I used three spray cans of internal frame paint. With the two foot hose and nozzle I did snake up past the control arms maybe all the way to the front of the frame. The cost of the paint less than my time I think I put it on fairly heavy but I really cant see. It is very runny and probably most of it is on the bottom rail which may be better?. I did not get any of the frame around the rear wheels and back.
I purchased one spray can and one quart of rust encapsulator. I used half the can applying several coats with a brush. No brush marks. I then used the spray for areas I could not reach with a brush. I was able to get every area that you can see.
I used two spray cans of the frame paint. Might have been able to get by with less but I put on two coats.
Iasked eastwood if oil would affect internal frame paint. They honestly do not know. For kicks I put a little on a rusted piece of steel. I am going to put some oil on part of it, cover it up and put it outside for a while. Just to see what happens.
It sounds like I may have enough to do the entire frame. I guess it will depend on how heavy and how many coats...
It does look very nice, I hope mine turns out as well.
Jeff
