Replacement frame ...shes clean
Old Apr 8, 2015 | 02:29 PM
derek15003's Avatar
derek15003
Default Replacement frame ...shes clean
1969 replacement frame. Blasted and coatwd inside and out. What you think?
Old Apr 8, 2015 | 04:08 PM
JimLentz's Avatar
JimLentz
Nice!
Old Apr 8, 2015 | 04:17 PM
briankeery's Avatar
briankeery
Great place to start, good luck.
Old Apr 8, 2015 | 04:27 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
There's the old saying "It's clean enough to eat off of it".......
but then it would have salad dressing and bread crumbs on it!
It looks great
Old Apr 8, 2015 | 04:30 PM
Paul L's Avatar
Paul L
Looks A++ to me!
Old Apr 8, 2015 | 04:36 PM
SB64's Avatar
SB64
Looks like a real nice frame and like others mention a great starting point.
r
Old Apr 8, 2015 | 06:46 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I think it looks outstanding. Nice job. What did you use to coat it inside and out? Love that look and what a great place to start from for building/rebuilding your car.
David
Old Apr 8, 2015 | 09:21 PM
mikem350's Avatar
mikem350
I would take lots of measurements from shock towers and other points to make sure its straight side to side front to back etc.
Sure is nice to see it so pretty!!!
Old Apr 8, 2015 | 09:42 PM
68/70Vette's Avatar
68/70Vette
First of all, I've cleaned up the frame on my 68, got rid of all the grease, etc and repainted it. Similarly, the frame on my 70 is completely clean and repainted. But..the frame welding just looks terrible..even though it looks stock, factory, etc. The frame welding tends to be sort of spotty, some sections of the frame halves are not welded. What if someone made continuous welds all along the frame, and then ground down the welds smoothly and got rid of the splatter. It'd look really nice, but when the car was fully assembled, no one would notice. Seems like something a perfection nut would want to do.
Old Apr 8, 2015 | 10:01 PM
Kris Tunetso's Avatar
Kris Tunetso
Looks good. Definitely suggest taking measurements to make sure it's straight. Also, and this is just me, I'd weld it up and stiffen it per the Chevy Power Book. Even if you're not planning on racing it a stiffer frame will help the car handle better.
Old Apr 8, 2015 | 10:35 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
That looks clean enough to eat off of.
Not that i will ever get my frame that clean, i would check the frame specs to the manual for correctness.
Old Apr 8, 2015 | 10:55 PM
derek15003's Avatar
derek15003
The coating is a SEMA product that I got from a local frame shop. I will def. measure. And you are right about the factory welds. They really enhanced after paint
Old Apr 9, 2015 | 08:52 PM
Dean_Fuller's Avatar
Dean_Fuller
Looks great! Where do you get the frame dipped?
Old Apr 9, 2015 | 09:05 PM
derek15003's Avatar
derek15003
The Pittsburgh area is crawling with corvette shops. Media blasters and alot of people with tons of knowledge.
This frame was sent out for blasting. Rust preventative was sprayed inside and hung at different angles. Then epoxied. Brought back to the shop and sanded with 220. Sprayed on the SEMA coating. Outside and inside. Then let hang. Took me 6 months to get it back from the guy I hired. It is a 69 big block frame with a welded in crossmember. I wish i could have gotten side by sides of my frame next to it. It def. looks beefier but my other was rotted completely. If you look on my posts you can see the rot. Overall I am happy. The 6 months allowed me to gather parts, components and Money!! She will go together quick hopefully!
Old Apr 9, 2015 | 09:10 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Again, great job
It looks solid.
If all is in rack it should out last you.
I'd love to take my 68 down but know I'll never find the time.
Marshal
To Replacement frame ...shes clean
