Found Spark Plug crush washers
Old Apr 12, 2015 | 08:00 PM
zwede's Avatar
zwede
Default Found Spark Plug crush washers
So I have these aluminum heads that use gasketed spark plugs. And I'm one of those OCD types that constantly inspects my plugs. But the crush washers are one-time use. I kept seeing oil on the plug threads because the gasket was not sealing anymore.
Don't want to throw away almost new plugs just because of the gasket so I set out to find replacements. Not easy. Several hours of googling and the consensus was "not available separately".
But then I found a reference to Champion N678 and lo and behold, there was the elusive washer. Available from both Summit & JEGS for about $30 for a bag of 1,000. Yeah, it will be a lifetime supply.
Old Apr 12, 2015 | 08:34 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Nothing wrong by having an ample supply of specific inventory, Markus.
At the least, it's one less item to be concerned about, right?
Plus, you're in good OCD company with some of the rest of us here.
Old Apr 13, 2015 | 09:56 AM
REELAV8R's Avatar
REELAV8R
Boy that OCD thing must be a real hassle at times.
I have not once in over 35 years of using plugs on aluminum heads changed the crush washer or even considered it an issue.
I had to take plugs in and out all the time on 2 stroke bikes. Oil on the threads, yes from the two stroke oil in the combustion chamber if idled a lot.
Check mine on the vette fairly often for jetting adjustment or wear, never had oil show up on the threads either. Wouldn't that indicate that excessive oil is getting past the rings to the plug?
Old Apr 13, 2015 | 10:27 AM
zwede's Avatar
zwede
I never used to think about the crush washer either, but a while back I decided to fix my oil leak once and for all. Replaced rear main seal, oil pan gasket and valve cover gaskets. After that I still had a stubborn couple of drops that just wouldn't stop. Finally traced it to oil being pushed past the spark plugs. Replaced the plugs and since then it's dry under the car.
Oil consumption is more than I'd like but not excessive. About 1 qt every 1,000 - 1,300 miles. Since all my driving is short distance it's acceptable.
Old Apr 13, 2015 | 11:55 AM
mikem350's Avatar
mikem350
Maybe the threaded plug holes are slightly oversize? Or try a different plug mfgr?
Try a little anti-seize, its thick and might help both in preventing seizing and leaks too.
Old Apr 13, 2015 | 04:07 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
they make a great stocking stuffer
Give 8 away on the forum at christmas time
and till have 2 life times worth.
Marshal
Old Apr 13, 2015 | 04:09 PM
7T1vette's Avatar
7T1vette
Most of today's spark plugs are not machined with precise tolerances...especially the angle on the plug base. If it is not correct, it won't seal well and the crush washers are needed.
Old Apr 13, 2015 | 04:10 PM
zwede's Avatar
zwede
Hah! Yeah, using 1,000 of them will take a while.
To Found Spark Plug crush washers
