M22 Question
Old Apr 19, 2015 | 10:03 PM
Alxnaj's Avatar
Alxnaj
Cruising
Default M22 Question
I have a '68 L71 with the original M22 'Rock Crusher' transmission (1 of 80), and 4.11 gears. Would anyone know how many of these 80 are actually in the L71's? I can only assume most were in the L88 & L89's..
Old Apr 20, 2015 | 01:06 AM
early shark's Avatar
early shark
All 80 M22 optionally ordered transmissions in 1968 were a mandatory ordered part of the L-88 package. No L-71/L89 ordered Corvettes in 1968 or 1969 ever were equipped with a M22 heavy duty 4 spd transmission.
Old Apr 20, 2015 | 06:28 AM
bashcraft's Avatar
bashcraft
In light of the information provided by early shark, what makes you think your M22 is original to your car?
Old Apr 20, 2015 | 07:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check for the VIN derivative stamped on your transmission.
Old Apr 20, 2015 | 05:37 PM
Alxnaj's Avatar
Alxnaj
Cruising
I wondered about that...Thanks. The 3 previous owners provided hand written documentation that the M22 was original, but the original tank sticker only partially shows "M2_...cant quite make out the rest. I guess I'll have to find the transmission stamp, as I dont think the Protect o plate identifies it. Appreciate the info!
Old Apr 21, 2015 | 11:33 PM
Alxnaj's Avatar
Alxnaj
Cruising
So the L71 was only availible with the M21 Close Ratio 4-spd. I'm going to check for the 4.11's..
Old Apr 26, 2015 | 06:08 PM
Alxnaj's Avatar
Alxnaj
Cruising
I'm still confused?...
1968 - 1969 1" Bore Patent Number (3) Colvin's "by the numbers" book notes that Muncie data shows 1968 and 1969 M22 transmissions received main case #3925661. All documented M22 transmissions have the #3925660 main case. It is unclear why there is the discrepancy.
PIC 1
STAMP#3925660
US PATENT NO 3088336
(AND DRAIN PLUG)
=M22? (NOT FACTORY)?
PIC2
PARTIAL VIN AND P8S09
=FACTORY? MUNCIE NOV09 1967
PIC 3
REAR AXLE
Old Apr 26, 2015 | 08:52 PM
JC68's Avatar
JC68
Alxnaj
GM docs all say that the L71 engine was only available with the M21 transmission, so I would be shocked to find you have something other than that. It is simple to add a drain plug and many have done it, so that is not a reliable indicator of an M22. Even the gears can be easily changed.
For 1968 and early 1969 you can't tell if it is a M20, M21, or M22 from the POP or transmissions stampings. They simply tell you the date the transmission was made and the car vin it was put into. Later in the 1969 model year they started stamping A, B, or C at the end of the date to denote the type.
Does your transmission still have the metal tag with the part number on it? With this you should be able to determine M21 vs. M22.
Your rear end code of FA on the POP is a HD 3.70 rear end used in BB applications.
John
Old Apr 27, 2015 | 10:02 PM
Alxnaj's Avatar
Alxnaj
Cruising
[QUOTE=JC68;1589504138]Alxnaj
John[/QUOTE
The metal tag isnt where it should be. Does this different casting no. mean anything? 38996621
Old Jun 18, 2021 | 05:12 PM
frankmingo's Avatar
frankmingo
4th Gear
Default M22 Transmission on a 1968
I have a 1968 327 / 300 hp with what looks like a M22 Transmission. I have attached a picture the vin number matches the engine and the car. Can you please confirm.
Originally Posted by JC68
Alxnaj
John
Old Jun 18, 2021 | 06:12 PM
JC68's Avatar
JC68
Frank,
The P8M22 you see stamped on the transmission is the date code. P - Munice, 8 - model year, M - August, 22 - day.
A suffix code of A, B or C at the end of the date would signify the type. A = M20, B = M21, C = M22.
The suffix code didn't start until early in the 1969 model year.
John
Old Jun 18, 2021 | 11:09 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
You have started a thread on this, please do not resurrect a 6yo thread just to repeat your question.
Old Jun 19, 2021 | 03:04 AM
vettebuyer6369's Avatar
vettebuyer6369
You are posting your question in answer to a post from 6 years ago. I’d tell you to start your own thread but it appears you have done that already. Let’s keep your responses confined to that thread.
To M22 Question
