73 dash question
Old Apr 23, 2015 | 07:03 PM
bertmac1111's Avatar
bertmac1111
Default 73 dash question
Should the main wiring harness run over or under the steering column?
Bert
Old Apr 23, 2015 | 07:11 PM
Zoix's Avatar
Zoix
Default Dash harness
Just like it is. It will sit on top of the speedo & tach housings as well. You need an AIM which will give you a good reference.
Old Apr 23, 2015 | 09:49 PM
bertmac1111
thanks
Old Apr 24, 2015 | 08:01 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Zoix
...You need an AIM which will give you a good reference...
Yep.
Old Apr 25, 2015 | 12:15 AM
Msbfdx's Avatar
Msbfdx
There are hanger clips on the back of the speedo and tach that hold it up relatively high on the dash.
Old Apr 25, 2015 | 11:34 AM
bj1k's Avatar
bj1k
And you will need to get it positioned just right or the dash won't go back into position. Can be a royal pain. Get yourself an AIM ( Assembly Manual ).
To 73 dash question
