Looking to add power door locks
Old Apr 25, 2015 | 02:20 AM
Sniper4x4's Avatar
Sniper4x4
Default Looking to add power door locks
My 75 doesn't have power door locks but I'm interested in adding two motors and tips and tricks? I've added power locks to around 15-20 different vehicles, the hardest was on a 68 VW Bug since the doors are so thin. What is the easiest preferred option for a 75 Vette?
Old Apr 25, 2015 | 08:17 AM
CraigH's Avatar
CraigH
I recently added them to my 71.
Covered on this page .... https://www.corvetteforum.com/forums...ourney-37.html
Old Apr 25, 2015 | 09:33 AM
Richard454's Avatar
Richard454
Here's another idea- I found this on the web and thought it was a great idea as it kept the geometry the same - easy to do- just get a large washer and drill some holes. Not my install but forum member DB's.
Another tip- don't put the relays in the doors- you slam the door and the relays can connect - lock the doors when you are not expecting it- not to mention the water.
There are basically two types of aftermarket lock motors- I went w/ the low profile type pictured below-these are DEI brand.
Old Apr 25, 2015 | 09:02 PM
7T1vette's Avatar
7T1vette
With fiberglass car, you have to run a good ground wire into the door to wire it up. If you have power windows, you could use the motor ground wires for that [common] ground. While you're in there, clean out the lock mechanism and regrease it and linkage points with [tube] white lithium grease. Those actuators won't do the job with 'sticky' linkage and latch parts.
To Looking to add power door locks
