71 firewall splash shield help
Corvette Splash Shield, Right, Inner, Without Air Conditioning, 1969-1975
I've rearranged my panels here, on the left half are my original, the right side are the new replacements:
This is the CC part:
You can see in the image how the passenger side is not right while the CC part seems to be perfect. I'm going to assume that Ecklers is at fault here as it should not list this part for 69-71.
I also seem to notice on my originals that the drivers side seems to be black while the passenger seems to have no color.
Can someone confirm that mine looks correct and Bubba (there's very little left of him on my car these days) didn't screw with me and put the wrong ones on?
SL
So Paragon, CorvetteCentral, and Ecklers don't seem to make any sense to me as to what is correct. The only thing I know is that the CC part looks to be the one I wanted in the first place.
Freaking frustrating.
r
These are the shields from my 71.
The way the tabs are shaped (not incorrectly bent) has a bit to do with how they fit.
Regards,
Alan
M
Apparently not, mine looks the same
Last edited by Mooser; Apr 29, 2015 at 09:26 PM. Reason: Nope, wrong, not the same
It seems pretty obvious at this point that CC is the only place that carries the correct L69-71 W/O AC passenger side firewall splash shield. All of the other vendors mark the 72 and later one as fitting a 69-71 which they will not, at least like they should.
I did order the CC part on Monday and it should arrive by Friday. I'll post the update then.
Thanks to all for your help. What are the chances that Ecklers will correct their part listing when I call and bitch and want to return it? I'll say 1%.
SL
The Automatics had a modification to the floor right about that area that could have affected that corner of the shield....
I'm gonna go look under the cover and see
M
OK, so here's what I see on a 72, auto, no-a/c
AIM says it's part # 6263552, gm parts wiki says that's 70-72 and 73-75 exc AC
Maybe the Ecklers one is the AC version?
M
On page L79 of my 1971 AIM, it shows a small image in the top left corner which is essentially the same image CC uses:
The AIM lists part 7 in the image as part # 3976545-6, which I'm assuming means two parts: 3976545 (drivers) and 3976546 (passenger). Indeed, if you look at the CC parts 303304 and 303357, you will see that CC lists the GM part# which matches up with those in the AIM.
Now if I look at the GMPartsWiki for the 3976546 part, it will say that it was replaced by 6263552. If you click on the wiki "parts history" link, you will get a page that lists this:
I'm not sure if that means that it was replaced by a new part on May of 1972 or not.
Anyways, here are some pictures of the passenger shield I ordered from CC. It's a spot on correct replacement piece for my old, presumably, original shield:
IMHO, CC has it right and all of the other vendors that I looked at (Ecklers, Paragon, Zip, Mid-America, Corvette America, Keen, Willcox, and even Dr Rebuild) have it wrong. Buyer beware.
SL
In post #11 you mention that the AIM lists 2 part numbers that are in sequence.
You're right that that means 2 parts, so know there're not the same on both sides.
In addition, the GM part number system is set up so that when there are right and left parts the right side part always ends in an even number and the left side part ends in an odd number.
Regards,
Alan
Regards,
Alan
