Removing rounded off bolts
Old Apr 29, 2015 | 07:54 PM
midigike's Avatar
midigike
Default Removing rounded off bolts
Well it all came down to one bolt, and bam rounded it off. Not a Corvette, but a front wheel bearing assembly for a Chevy Silverado 4x4. Everything is so rusted, everything fought me the whole way. I was going to file it back clean and maybe beat a six point socket on and see if I can blast it again with a air gun. But the space is tight and have to be carefull of the CV boot. We seem to run into hard to get out bolts on our Corvettes, do you pros have any suggestions or tricks, thanks for any suggestions!:smashName:  image.jpg
Old Apr 29, 2015 | 08:09 PM
Paul L's Avatar
Paul L
Extractor sockets. They grab in reverse direction. Sears. Hammer drill helps!
Old Apr 29, 2015 | 08:11 PM
BKarol's Avatar
BKarol
Happened yesterday on a bolt on the front end. Went to Lowes and bought this: http://www.lowes.com/pd_577634-281-3...=50146292&Ntt=
The bolt was 1/2 inch.
Old Apr 29, 2015 | 10:37 PM
pltmgr's Avatar
pltmgr
If possible I would apply daily applications (with banging) of PB blaster for a week before using an extractor to possibly avoid breaking the head off.
Old Apr 29, 2015 | 10:54 PM
Praxxus's Avatar
Praxxus
I usually clean those as clean and dry as I can get then then hammer a clean nut over the head of the bolt as tight as it will go. Fire up the mig welder and weld the nut and bolt together through the hole in the nut then turn it out. Don't forget to stick something over the CV boot to shield it from sparks if you try this!
Old Apr 29, 2015 | 11:11 PM
71 Vert LS1's Avatar
71 Vert LS1
PB blaster and new vise grip with perfect teeth for a great bite. If it breaks the head off looks like there is room to drill and tap.
Old Apr 30, 2015 | 12:40 AM
vbgod1's Avatar
vbgod1
Just about every case like this is its own unique situation. Removing rounded or broken bolts is one of the hardest things to teach/learn. The extractors are awesome, lots of PB blaster and patience works well, sometimes a small chisel and hammer gets it. Lately, I have been experimenting using a Mini Ductor to heat the bolt, and I am getting better with that.
I think my next step would be PB blaster overnight and one of the extractors.
Old Apr 30, 2015 | 06:21 AM
midigike's Avatar
midigike
Thanks for all the replies.
Yes I was thinking going the extractor route, but they are too big and do not fit between the side of the bolt and CV boot, approx. 3/8 clearance, 15mm bolt
I have been soaking it with PB for a week!!! It is the front bolt so gets hammered by our salty roads here.
I'm gonna weld a nut on, that I can do!!! Kudos Praxxus!!
I will follow up and post with pictures.
Old Apr 30, 2015 | 07:35 AM
gungatim's Avatar
gungatim
in my world, I wouldn't even consider that rounded, but either way, I would use some heat and a spray bottle of watter. heat and cool a few times (try not to heat the bolt itself) if you have a set of acetylene torches, that should come right off. if the 15mm slips, try a worn 9/16".
Old Apr 30, 2015 | 10:04 AM
bj1k's Avatar
bj1k
I have a set of these and they work great.
Old Apr 30, 2015 | 08:28 PM
7T1vette's Avatar
7T1vette
For corroded bolts, 12-point sockets are a total waste. Use good 6-point sockets AFTER soaking with penetrant overnight....or buy the extractors.
Old Apr 30, 2015 | 09:33 PM
learje's Avatar
learje
if u can get a good 6 point on it u can probably get it right out. doesnt look too rounded off. id try the correct size, even if u need to hammer it on some, or a 9/16 as stated above. get it on fully. soak w pb overnight or longer first. might get lucky. trick is to not go with the agressive approaches till necessary
Old May 1, 2015 | 07:41 AM
jnb5101's Avatar
jnb5101
You need to get the PB blaster (or 50/50 mix of acetone and auto trans fluid) onto the threads of the bolt, not the head.
Old May 1, 2015 | 11:36 AM
Aquarian's Avatar
Aquarian
I've come to be quite handy with my torch...cover the exposed soft material with a wet towel and hold the torch on the head and around the bolt head then spray some pb into it, let it sit overnight and try the extractor heads next day. repeat procedure if necessary. Worked for me on some serious rusted stuff. and as always use caution! ps: I agree, 6pt sockets only on old stuff!
Old May 1, 2015 | 12:29 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
To Removing rounded off bolts
