must replace heater hose on my 73 and want to go factory correct. Did both have the GM stamp or just the top? One supplier says both, another says top only. Were they ribbed?
Hi gbw,
I don't think that your 73 had the GM stamped hoses originally.
I believe they had various numbers of raised ribs in them and 2 letter codes stamped on them.
Regards,
Alan
Hi gbw,
Regards,
Alan
Red is not an option I would chose. Talked to Corvette. Central today. They say NCRS used to require white letters, but has changed to black ribbed. Therefore the put both as correct in mag. I am considering ordering black and sen white letter back when the black arrive.
Hi gbw,
That's pretty close.
The GM[] was typical on later C2 Corvettes... There was some carry over into 1968, but for the most part, that was it. Later cars used a two letter broadcast code in white that identifies the application and a series of grooves (not raised ribs) that denote the hose manufacturer.
Regards,
Stan Falenski
Stan, I suppose they are no longer being manufactured? Mine is a May 73 build. I am not ready for judging yet, but thought would go ahead and get this part done. Everything else is original to car except carb and front floor carpet.
You can hunt salvage yards for old passenger cars and pickup trucks... They use the same hoses and while the broadcast codes will be different, nobody really has a handle on that yet (or the grooves for that matter) and the configuration is spot on. The downside of course is using 40+ year old heater hoses. That may be OK for a car that is never driven, but for most of us, it isn't practical.
Second option is to go with a good reproduction hose. You'll be missing the broadcast codes, but the configuration is really close and you won't be worrying about when that old hose is going to let go. I've used Dr. Rebuild for my heater hoses and have never had a problem during judging with them. Other suppliers may offer a suitable product, but I have no experience with them so I can't offer any other suggestions.
Regards,
Stan
Thanks Stan. I don't want to risk more old hose. I decided to go with the GM in white until I get a few more things done to it. I think the will be well received at the regional shows I go to. Getting good input at every one of them for when I want to go the NCRS route. Can change them out then. Did not know about Dr Rebuild. Many thanks.
Been awhile since on forum, but update: When I took the old hose off the 3/4 had 2 white strips and EBDM EB D09142 in white, the 1/2 had one white strip with 78E60 EBY 221 D12182 in white on it.
